Bubble chart does not display using any manager
I have a node that does not display the bubble chart regardless of what manager I am using.... the node is on allstarlink ok with an iax port. What affects the display of the bubble chart? Raspberry pi appliance on 616993
Appearance on the bubble chart is solely dependent on the node sending the statpost information to the stats server in app_rpt. No "manager" matters.
OK... so how to I get the statpost information to go the stats server?
Assuming that you are running ASL3 :
sudo asl-menu
Node Settings
AllStar Node Setup Menu
Update node ...
Post node status -> Yes
<Back>
<Back>
Restart Asterisk
Thank you... that was easy!
