I have bf 888s its transmit audio and receive but when receive the green led shows up and no sound from speaker but the voice prompt works and the original programme on it i don't know what i should do is there like pin can get direct audio or can fix it
Are you asking about hooking up a BF888S to an AllStarNode? Your question is not clear.
I was trying to hook but the radio its transmit but no sound out i have unhooked it And I re-soldered it again. Its transmit as normal but the other radio when transmit its blinking green but nothing I have checked everything.
You cannot hook up an BF888S to AllStarLink without taking it apart and modifying the internals to tap the COS line and, I think, maybe the audio out? I've never done it. There's a lot of information on YouTube and the Internet about it, but it varies widely because there are many variants of the BF888S that all are labelled the same.
I was trying but stopped in some point and reverted back but sound receiving not working now i want to make work as normal
Perhaps you are draining the circuit where you attached the COS ?
(to much load)
I believe it's better to use that LED indicator along with a buffer transistor on low power circuits.
And it keeps you away from more sensitive areas.
But I know the guides tell you differently.
I am no additional help since I don't use these.
I have started to use some of the commercial handhelds for my Allstar nodes. The Baofeng 888's are OK but there are an increasing number of radios available from companies such as Motorola, Hytera and Tait appearing on the market at good prices. These radios are excellent in terms of the RF quality. They seem to stay cooler and if you choose a radio that is both A/D you can build an AllStar node that can receive Analogue and Digital signals. There are some details on my qrz page. G0JSV. I will put a few pictures up of the latest version of the node, now in its case, in the next day or two.
