Block unwanted node
Born out of need.
recent problem with an Allstar node owner caused the creation of this program.
the ban_nodes script runs along side of the rc.updatenodelist script and watches for updates to the rpt_extnodes-temp file and removes the offending node. if you have iptables installed and configured you may set that option to “yes” in the program itself
simply use the bannodes.conf file that is created in the /etc/asterisk directory to add or remove nodes as needed.
you may view / download the script at http://n8thn.net/scripts/index.html
I also have my updated TTS script that works in place of the google_tts.py for the underground WX report.
Nathan Hardman
nhardman1428@gmail.com
N8THN@ARRL.NET
Can't you just do like:
[nodes]
40821 = nope@127.0.0.1
and then it will try not let that node connect as it's redefined and over
rides the ext-nodes file?
On 8/7/17 10:34 PM, Nate Hardman wrote:
Born out of need.
"yes" in the program itself
Bryan Fields
727-409-1194 - Voice
http://bryanfields.net
that hasn’t worked well and also requires a “rpt reload” each time. this allows (on the fly) ban/unban each time rc.updatenodelist updates the rpt_extnodes-temp file they are removed or unbanned (not removed) I also just built a php page to edit the ban list via web page and will be posting that along with the script and the directions for proper use.
Born out of need.
Can’t you just do like:
[nodes]
and then it will try not let that node connect as it’s redefined and over
Bryan Fields
Nathan Hardman
N8THN@ARRL.NET
You add the line to rpt.conf.
It doesn’t change when the list gets updated.
David
Thanks, David
“Laws that forbid the carrying of arms…disarm only those who are neither inclined nor determined to commit crimes. Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than prevent homicides, for an unarmed man may be attacked with greater confidence than an armed one.”
Thomas Jefferson
Born out of need.
[nodes]
Bryan Fields
Nathan Hardman
N8THN@ARRL.NET
