When I attempt to connect to some Echolink nodes or conference servers, they show up on the Supermon connected stations list with a red background and yellow text as it tries to connect. After 3-5 seconds it disappears from the list (does not connect).
On the old ASL node where my -L Echolink node was configured, there were no connection issues.
What should I check to see if this is a bug or some other type of issue? Thanks!
Did you forward all echolink ports to the node? Be sure ports 5198, 5199, and 5200 are forwarded. Also, be sure there is no multiple echolink connections on the same network, only one at a time can go through, unless you make the other connections go through proxy servers.
