I’ve begun to setup a MAN/WAN (yes computer terms for Metropolitan/Wide area network) centered at the moment around my node.
So far I’ve pointed an Echolink node to mine, a second node (simplex repeater) and a 3rd personal node.
The second node also has an Echolink node connected to it. This node has a permanent connection to my node.
We are communicating with other Repeaters (duplex) w/ALLSTAR for temporary (scheduled) or permanent connections.
Everything works, but here’s the best practice questions.
- I haven’t tried this, but I am assuming ONLY one set of links between node A and node B is possible at a time.
- Currently, my node and the second node produce station ID’s. Do we turn them off, limit them and if so, how?
- Same question but modify for SkywarnPlus tail messages.
Thank you for the collective insight.
