Hi Birton,
What image are you using? After downloading the image and unzip’ing the image, what is the md5sum (use Linux utility “md54um ”
It’s possible that you are getting a truncation of the file. Here is the latest md5um of BBB image that I downloaded:
md5sum BBB_Allstar_1.2.1.img
99351fca14d84c608be6420d556e967d BBB_Allstar_1.2.1.img
md5sum BBB_Allstar_v1.2.1.zip
7757d3ad29ee4635698d91c2dc4285ac BBB_Allstar_v1.2.1.zip
For Linux systems in creating the image, I unzip the image and use the dd command (as root) as follows:
unzip BBB_Allstar_v1.2.1.zip
dd if=BBB_Allstar_1.2.1.img of=/dev/sdh bs=1M
note: the device in the above example is the one my system recognizes for the sd card.
Also, if you are creating the image on a Linux system, you can check the image in a couple of ways… Once the image is created, remove and re-insert the sd-card. Determine the device that the sd-card is being recognized. In my case, it’s the “/dev/sdh” device. You can then check the partitions:
fsck -C -f /dev/sdh1 (fat file system)
fsck -C -f /dev/sdh2 (ext4 file system)
Also note, some Linux distributions will automatically mount the sd-card. You will need to umount the file system prior to running file check (fsck).
I suspect that the image may be corrupt.
73, Happy Holidays,
Chris, w0anm
On Wed, Dec 23, 2015 at 12:36 PM, Birton [email protected] wrote:
Hi,
Using these instructions, I’ve tried to reload my BBB with the new version.
http://www.crompton.com/hamradio/BeagleBoneBlackAllstar/#image
Hardware: BBB Rev C
SDCARD: 8bg
Actions:
Burned the img to 2 different cards (including the one I’m running) using Win32Imager
Burned the img to 2 different cards (including the one I’m running) using linux dd
Result:
Blue Power Light on
NO Other Blue Light Activity
NO Boot
Nothing on HDMI Display
Fall back: Re-Burned the original image to same card and system back running.
Suggestions?
Birton, N6UG
[email protected]
