Im working on a bash shell to make some connection via rpt fun and the asterisk cli. Is there a way to insert the extension/node number that triggers the shell into said shell automatically?
John Rudolph
Amateur Radio Op N2YP
Unadilla,NY
Like this?
asterisk -rx “rpt fun 1000 *70”
!#/bin/bash
LOCALNODE=“2000”
REMOTENODE=“2001”
/usr/sbin/asterisk -rx “rpt fun ${LOCALNODE} *3${REMOTENODE}”
Should work?
On Tue, Mar 20, 2018 at 9:03 PM, Skyler F electricity440@gmail.com wrote:
Like this?
John Rudolph
Unadilla,NY
Skyler Fennell
amsatnet.info
KDØWHB
I think what you're asking here is can you export a variable to it from within
app_rpt?
http://docs.allstarlink.org/drupal/node/94
Look at:
Get a detailed directory listing of the '/tmp' directory, and put its output
into the file '/tmp/example.txt' every time node 2001 is connected to, and
stops indicating keying towards our node
(not that anyone would ever really want to do that... its just an example).
TEMPVAR = v|e|${RPT_ALINKS} =~ "\",2001[TRC]K\""
ls -l /tmp > /tmp/example.txt = s|f|TEMPVAR
Basically you can define an action to take when a VAR is set and then pass
that var to the action on the command line.
Bryan Fields
727-409-1194 - Voice
http://bryanfields.net
Or, if you want to call a single script from multiple DTMF commands; for instance, a shell called connect.sh:
#! /bin/bash
/usr/sbin/asterisk -rx "rpt fun $1 *3$2#"
for instance, to connect, being called from the DTMF functions:
dtmf1=cmd,/etc/asterisk/scripts/connect.sh node1 node2
dtmf2=cmd,/etc/asterisk/scripts/connect.sh node1 node3
where dtmf1 = some valid dtmf sequence
node 1 = the node you're sending the command to
node2 = the target you want to connect to
etc.
You could get even fancier, though I haven't tried it, where you pass both the node numbers AND the command to the script:
#! /bin/bash
/usr/sbin/asterisk -rx "rpt fun $1 $2$3#"
in rpt.conf:
dtmf1=cmd,/etc/asterisk/scripts/command.sh node1 command node2
such that dtmf1 = some valid dtmf sequence
node1 = node you're sending the command to
command = the app_rpt command
node2 = the target
You won't break anything...so experimentation is fun...
Bryan
WB0YLE/W2FUV
Morrisville PA
On 3/20/2018 9:59 PM, Sam Nabkey wrote:
!#/bin/bash
LOCALNODE="2000"
REMOTENODE="2001"
/usr/sbin/asterisk -rx "rpt fun ${LOCALNODE} *3${REMOTENODE}"Should work?
CORRECTION:
***deletia***
Should be
/usr/sbin/asterisk -rx "rpt fun $1 *$2$3#"
which makes the command line (for instance, to connect):
dtmf1=cmd,/etc/asterisk/scripts/command.sh 12345 3 56789
to connect node 12345 to node 56789
to disconnect...
dtmf2=cmd,/etc/asterisk/scripts/command.sh 12345 1 56789
One shell. Multiple uses. Cleans out the cruft in all our local script directories (if we have them...and you should...)
note...you need the first node and the command...if you leave off the second node, it drops through and executes the command on the node1.
I'm sure it could be juiced up a bit with some error checking and logging and such...(which I'll do to send stuff to my local QRadar instance here looking at my home network), but, you get the drift.
EXPERIMENT folks...you won't break anything.
Bryan
WB0YLE/W2FUV
Morrisville PA
On 3/21/2018 11:12 AM, Bryan D. Boyle wrote:
And, you can chain commands...calling existing scripts...
84=cmd,/etc/asterisk/scripts/command.sh 12345 86
calls...
86=cmd,/etc/asterisk/scripts/forecast.sh
I know, kind of bogus (I've tried it and it works...), but one of those "I wonder..."
Using the event management subsystem to, for instance (I don't know if you can do this...but...would be interesting to hack at it...), write the incoming node number to a temp file, read in that temp file as node1 and do something with it.
Point being, combining the power of asterisk with the almost unlimited utilities in the underlying OS...haven't even begun (after all this time) to tap what is possible.
Bryan
WB0YLE/W2FUV
Morrisville (snowy) PA
On 3/21/2018 11:23 AM, Bryan D. Boyle wrote:
Should be
/usr/sbin/asterisk -rx "rpt fun $1 *$2$3#"which makes the command line (for instance, to connect):
to connect node 12345 to node 56789to disconnect...
dtmf2=cmd,/etc/asterisk/scripts/command.sh 12345 1 56789One shell. Multiple uses. Cleans out the cruft in all our local script directories (if we have them...and you should...)
Hello everyone,
I want to have my LOGS with the .CVS file
I created a CDR.CONF file in etc/asterisk
[general]
enable = yes
loggingsfeshutdown = yes
[CSV]
usegmtime = yes; log date / time in GMT. Default is “no”
loguniqueid = yes; log uniqueid. Default is “no”
loguserfield = yes; log user field. Default is “no”
and
with PUTTY in “11 - Run asterisk CLI Client”
I put in the command line “module load cdr_csv.so”
and I have an error message
raspberry * CLI> module load cdr_cvs.so
[Mar 21 17:35:55] WARNING [8179]: loader.c: 361 load_dynamic_module: Error
loading ‘cdr_cvs.so’ module:
/usr/local/hamvoip-asterisk/lib/asterisk/modules/cdr_cvs.so: can not open
shared object file: No such file or directory
[Mar 21 17:35:55] WARNING [8179]: loader.c: 655 load_resource: Module ‘cdr_cvs.so’
could not be loaded.
raspberry * CLI>
I even created in modules.conf
load = cdr_cvs.so
; Asterisk configuration file
; Loader configuration file module
[Modules]
autoload = yes
noload = chan_oss.so
noload = chan_alsa.so
noload = chan_phone.so
— Make by LUC —
load = cdr_cvs.so
noload = func_moh.so
noload = res_musiconhold.so
noload = res_speech.so
; Noload = res_crypto.so
noload = res_odbc.so
noload = res_smdi.so
noload = res_config_odbc.so
For what it does not work and where I will find my .CVS file
Thank you for your help
Luc
Try: module load cdr_csv.so
NOT: module load cdr_cvs.so
73, David KB4FXC
On Wed, 21 Mar 2018, Luc Drolet wrote:
Hello everyone,
[general]
enable = yes
loggingsfeshutdown = yes[CSV]
usegmtime = yes; log date / time in GMT. Default is "no"
loguniqueid = yes; log uniqueid. Default is "no"
loguserfield = yes; log user field. Default is "no"
and
with PUTTY in "11 - Run asterisk CLI Client"
I put in the command line "module load cdr_csv.so"
[Mar 21 17:35:55] WARNING [8179]: loader.c: 361 load_dynamic_module: Error loading 'cdr_cvs.so' module: /usr/local/hamvoip-asterisk/lib/asterisk/modules/cdr_cvs.so: can not open shared object file: No such file or directory
[Mar 21 17:35:55] WARNING [8179]: loader.c: 655 load_resource: Module 'cdr_cvs.so' could not be loaded.
raspberry * CLI>
load = cdr_cvs.so
;[Modules]
autoload = yes
noload = chan_phone.so; ----------------------
--- Make by LUC ---
load = cdr_cvs.so
; -----------------------noload = func_moh.so
For what it does not work and where I will find my .CVS fileThank you for your help
Luc
OK I made the correction and he says there is now
raspberry * CLI> module load cdr_csv.so
[Mar 21 19:13:26] WARNING [9425]: loader.c: 645 load_resource: Module 'cdr_csv.so' already exists.
but where are I going to find my files?
can you help me
Thank you
Luc
VE2LUQ
73, David KB4FXC
Hello everyone,
[general]
enable = yes
and
raspberry * CLI>
load = cdr_cvs.so
;[Modules]
autoload = yes
--- Make by LUC ---
load = cdr_cvs.so
Luc
http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-usersTo unsubscribe from this list please visit http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button"
Hi,
I believe you can find the CSV data files in this folder:
/var/log/asterisk/cdr-csv
73, David KB4FXC
can you help me
Thank you
Luc
VE2LUQ
73, David KB4FXC
Hello everyone,
[general]
enable = yes
and
raspberry * CLI>
load = cdr_cvs.so
;[Modules]
autoload = yes
--- Make by LUC ---
load = cdr_cvs.so
Luc
