Baofeng UV5R + DMK URI 's. (Wiring & COS etc?)
Giday!
So, still waiting on my Raspberry PI2 's. But they must be getting closer.
All other items ordered that same day from China have arrived 1+ weeks ago!
In the mean time I'd like to make the cabling up.
For our first attempt we're going to utilise some Baofeng UV5R 's that we already have handy.
Has anyone been down this trail before that can help with wiring instructions with the DMK URI 's?
Mainly interested if we need any cap's or resistors across any lines to to isolate audio or for COS etc?
Not interested in hacking into the radio's at all for internal connection. If it can't be done on the standard external connectors we won't bother.
However I doubt this will be the case as we have used them with the AnyTone portable repeater controllers and they detect COS etc A-OK from the basic connectors.
~Ken - vk4akp
Ken,
Unless you use a VOX circuit on the RX audio which I do not recommend you will have to go inside. We have used the Baofeng 888’s with success as node radios. Info on the mod is in the how=to section at hamvoip.org I believe the UV5 uses a similar approach.
73 Doug
WA3DSP
To: app_rpt-users@ohnosec.org
Date: Thu, 6 Aug 2015 13:31:00 +1000
Subject: [App_rpt-users] Baofeng UV5R + DMK URI 's. (Wiring & COS etc?)
Giday!
In the mean time I’d like to make the cabling up.
For our first attempt we’re going to utilise some Baofeng UV5R 's that
Mainly interested if we need any cap’s or resistors across any lines to
Not interested in hacking into the radio’s at all for internal
connection. If it can’t be done on the standard external connectors we
won’t bother.
~Ken - vk4akp
If you do not want to take apart your baofeng, you can still get COS.
Build this simple 1 transistor circuit
https://www.youtube.com/watch?v=QopvHGM-9_k
Even if the volume is all the way down, the COR detect still goes off when it gets a signal due to a DC offset in the radio i think. Just make sure you turn off the voice in the UV5R so it doesen’t go off when you press buttons.
See my portable AllStar node on my qrz.com page
73 Skyler
KDØWHB
On Wed, Aug 5, 2015 at 10:49 PM, Doug Crompton doug@crompton.com wrote:
Ken,
73 Doug
WA3DSP
Giday!
won’t bother.
~Ken - vk4akp
Skyler Fennell
amsatnet.info
KDØWHB
electricity440@gmail.com
