never had an issue before always worked
stock ASL build on Pi/Buster
node working fine
any suggestions appreciated
Clifford - KK6QMS
I’ll check on it. Thanks for the report.
I just tested on another node and saw the same result. (48654 and 52352 if it matters)
Could you post part of your
/var/log/asterisk log around the error (JUST BEFORE AND JUST AFTER ERROR)
Perhaps it may be telling.
All my event logs are empty and there is no “log” file. I also have connect, message, and que logs.
Are you attempting to backup your ASL settings locally (using asl-menu) ?
Or perhaps restoring them from local file ?
Backup is broken. I’m bugging on the guy that can fix it. He has limited availability.
