Automatic Reconnect and Logging
I have been experimenting with this for a bit, and have it working well. I am running a FT-991A connected via DINAH to a Raspberry Pi using allstar to connect to the East Coast Reflector. Sometimes there are ISP hiccups and it gets disconnected, and I don't realize it until hours later. So I wrote a little bash script to run and reconnect me if it needs to.
Raspberry Pi is running Arch linux, so it uses cronie instead of cron. I am running a check every minute, but you can change to your liking. Since it is cronie, the file I edit is /var/spool/cron/root.
I just added the line: * * * * * /var/spool/cron/check_connect.sh to the end of the file. I have my script check_connect.sh in the same directory.
Here is the bash file if you want to play around with it. I set it up with variables to make it easier to configure:
MYSITE is your node number
REMSITE is the node you are connecting to
LOGFILE is the name of the file you want to log to
LOGRECONLY is set to 1 or 0, where 1 will only write to the logfile if disconnected and needs to reconnect. This saves on logfile size. 0 will write to the logfile everytime the file is called.
Just copy and paste into your file and set your variables.
It's quite simple and straightforward. If I make changes to improve or update I will add to or refer to this thread.
Enjoy.
#!/bin/bash
####          KO4IYY          ####
####         Steve Clay       ####
####       steve@ko4iyy.com   ####
####  Simple script to check  ####
####  if asterisk is connected####
####  to your remote node.    ####
####  Used for East Coast     ####
####  Reflector connection    ####
####  via Raspberry Pi        ####
# Set this file up in your crontab to
# run at desired intervals
#  Change these to match your local settings
MYSITE="00000"
REMSITE="00000"
#  Change if you want to change the location of your logfile
LOGFILE="/var/log/checkConnect.log"
# 0 = Write all checks to log file, 1 = Only write when a reconnect is performed (saves on logfile size).
LOGRECONLY="1"
# You shouldn't have to change anything below
if [ "$LOGRECONLY" = "0" ]
then
        echo "#############################"  >> "$LOGFILE" 2>&1
        date "+%m-%d-%Y %H:%M:%S" >> "$LOGFILE" 2>&1
        CHK=""
        echo "Checking if connected to hub node "$REMSITE""  >> "$LOGFILE" 2>&1
        CHK=$(asterisk -rx "rpt nodes "$MYSITE"" | grep -c "$REMSITE")
        if [ "$CHK" = "1" ]
        then
                echo "You are already connected to $REMSITE." >> "$LOGFILE" 2>&1
        else
                echo "Reconnecting to $REMSITE...." >> "$LOGFILE" 2>&1
                asterisk -rx "rpt cmd "$MYSITE" ilink 3 "$REMSITE""
        fi
else
        CHK=""
        if [ "$CHK" = "0" ]
        then
                echo "You are DISCONNECTED to hub node "$REMSITE""  >> "$LOGFILE" 2>&1
                echo "Attempting to RECONNECT to "$REMSITE"...." >> "$LOGFILE" 2>&1
                if [ "$CHK" = "1" ]
                then
                        echo "Reconnect successful. Your node "$MYSITE" is now connected to ECR node "$REMSITE"." >> "$LOGFILE"
                else
                        echo "Reconnect unsuccessful.  I will retry next time this file is called." >> "$LOGFILE"
                fi
        fi
fi
You need to insert the vars earlier declared or instruct to edit there.
You are absolutely correct. Error on my part for cut n paste. Thanks for catching that! Edited.
