Audio Problems similar to X86_64 latest kernel in latest Raspberry Pi Appliance Kernel
Hello folks,
I have just learned, through personal experience, that the latest kernel that just dropped for the Raspberry Pi ASL3 Appliance (6.6.74+rpt-rpi-v8) has similar or same audio problems over a radio audio interface as the latest X86_64 kernels. Recommend that everyone running an ASL3 Pi appliance hold off on running sudo apt update && apt upgrade until the ASL3 team evaluates this and comes up with a fix. An audio example is located at: https://media.fedi.adamm.cc/media_attachments/files/113/924/316/565/808/973/original/9e21cafd2bb47a5b.mp3
Regards,
Adam, VA3AUM
Ughhh… I hope not. Testing this out now…
Yeah, that gremlin has popped up in the latest Pi image. Everyone running a Pi should immediately:
apt-mark hold linux-image-rpi-v8
apt-mark hold linux-headers-rpi-2712
apt-mark hold linux-headers-rpi-v8
apt-mark hold linux-image-rpi-2712
6.6.62 apppears to be the lastest safe kernel on RPi.
Hello N8EI.
Thank you for your prompt response in testing, confirming, and providing a temporary fix to this problem for users who haven’t already hosed their systems.
I’m curious though, since I’ve already updated to the problematic kernel, and a hold would do me little good at this point, what would be the proper rollback procedure on a Pi appliance to a known good kernel?
I’ve done this on vanilla Debian X86_64 systems before, but never to a Pi. Yep, I failed to back up the card before upgrading. LOL. I’m usually good with backups, but of course, the one time you don’t…
Adam, VA3AUM
Did you mean to write 6.6.69? or 6.6.62?
6.6.62, corrected above.
I believe I have developed a hotfix for the issue. Please try:
wget -O- https://repo.allstarlink.org/hotfix/asl3-pi12-kernel62-fix.sh | sudo bash
Note: this worked on my system but has not been widely tested. YMMV. Please report back.
Hello N8EI,
Thank you! Thank you! You totally saved the day on this one for me! Your BASH script worked. Audio to/from the radio is fixed, and the Pi 4B reports:
Linux ASL3-1 6.6.62+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.62-1+rpt1 (2024-11-25) aarch64
Thanks again!
Adam, VA3AUM
I’ve run this script on my own personal node with no issues at all, and things are running properly. I’m about to help a friend apply this fix to his node.
I’ll report back.
Hello,
I applied this fix to a friends node as well and it went off without a hitch.
A fix has been identified. Put the following in the file /etc/modprobe.d/asl3-snd-usb-audio.conf:
options snd_usb_audio lowlatency=0
Then reboot your system. This is being tested and packaged for a release today.
Worked for me. Raspberry Pi 4 using a URIx on ASL3
