Audio level for 2.5 KHz narrow band FM?
I’m playing with a 900 mhz repeater and most FM on 902mhz is narrow
band. As this is a converted uniden LTR repeater it’s setup for
narrow band.
Looking at which is the
allstarlink network standard, rather than 3khz of deviation before
CTCSS/DCS, what’s the value I should be shooting for here in a NBFM
system?
I’ve been researching it and there are some posts from 2009 by
Steve, WA6ZFT saying that 1.5 KHz of deviation should be the target.
Is there anything more official than this? Can we add some info on
this to the docs site?
73’s W9CR
http://docs.allstarlink.org/drupal/node/92
-- Bryan Fields
727-409-1194 - Voice
727-214-2508 - Fax
http://bryanfields.net
with a service monitor, i set it to peak at 2.4 or so with pl (which should be aprx 400 hz deviation or so.)
linking it to wb systems you will have to play around a bit. but these starting points worked for me (and have been using them for the last 4 years on 900.
others may (will?) have their own opinion; thiese numbers give a little cushion to start with.
-- Bryan Fields
727-214-2508 - Fax
I usually set my 900 stuff up this way. which is standard LMR settings.
±1.5kHz Voice Deviation
±0.35kHz CTCSS Deviation
±1.85kHz Total Combined Deviation ( Voice + CTCSS)
Some systems are set for ±2.4kHz combined, but no more than that.
YMMV
On Thu, Feb 5, 2015 at 8:52 PM, Bryan Fields Bryan@bryanfields.net wrote:
-- Bryan Fields
727-214-2508 - Fax
[http://bryanfields.net](http://bryanfields.net)
I'm playing with a 900 mhz repeater and most FM on 902mhz is narrow
narrow band.
Looking at [http://docs.allstarlink.org/drupal/node/92](http://docs.allstarlink.org/drupal/node/92) which is the
system?
I've been researching it and there are some posts from 2009 by
73's W9CR
Thanks in Advance
Bob Brown, WØNQX
Kansas City Metro Area
http://drsm0ke.net
http://byrg.net
http://sm0kenet.net
http://kcdstar.byrg.net
Quis custodiet ipsos custodes?
1.5khz is the setting we use on 900 radios both on the RX and TX sides. Makes sense to add that to the docs site and I’ll take care of that.
-- Bryan Fields
727-214-2508 - Fax
Thanks, how much PL/DCS deviation do you use on top of this? This is my first
900 mhz repeater :slight_smile:
Tim
:wq
On Feb 5, 2015, at 6:52 PM, Bryan Fields <Bryan@bryanfields.net >> <mailto:Bryan@bryanfields.net>> wrote:
I'm playing with a 900 mhz repeater and most FM on 902mhz is narrow band.
As this is a converted uniden LTR repeater it's setup for narrow band.
Looking at AllStarLink Wiki which is the
CTCSS/DCS, what's the value I should be shooting for here in a NBFM system?
I've been researching it and there are some posts from 2009 by Steve,
Is there anything more official than this? Can we add some info on this to
the docs site?
73's W9CR
Bryan Fields
727-214-2508 - Fax
App_rpt-users@ohnosec.org <mailto:App_rpt-users@ohnosec.org>
Bryan Fields
727-214-2508 - Fax
The PL setting should be half of what it is on wide band systems. So 3Hz or so should be about right.
you use on top of this? This is my first 900 mhz repeater :slight_smile:
of that.
            Tim
            :wq
wrote:
            I'm
narrow band. As this is a converted uniden LTR
repeater it’s setup for narrow band.
            Looking at which is the allstarlink network standard, rather than
3khz of deviation before CTCSS/DCS, what’s the value I
2009 by Steve, WA6ZFT saying that 1.5 KHz of deviation
some info on this to the docs site?
73’s W9CR
button”
via email confirmation. If you have trouble unsubscribing,
-- Bryan Fields
727-214-2508 - Fax
http://bryanfields.nethttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
-- Bryan Fields
727-214-2508 - Fax
Maybe you meant 300 hertz?
N5ZUA
So 3Hz or so should be about right. �
          Tim
          :wq
deviation do you use on top of this?� This is my first
site and I�ll take care of that.�
                    Tim
                    :wq
FM on 902mhz is narrow band.�� As this is a
narrow band.
posts from 2009 by Steve, WA6ZFT saying that
Is there anything more official than this?�
Can we add some info on this to the docs site?
73’s W9CR
can do it via email confirmation. If you have
-- Bryan Fields
727-214-2508 - Fax
-- Bryan Fields
727-214-2508 - Fax
Yes. Thank you for the correction.
          Tim
          :wq
                    Tim
                    :wq
FM on 902mhz is narrow band. As this is a
narrow band.
73’s W9CR
-- Bryan Fields
727-214-2508 - Fax
-- Bryan Fields
727-214-2508 - Fax
