I am setting a new repeater using a RPi4 running HamVOIP ALS connected to a Motorola SLR5000
The RIM is the RIM-lite
THe repeater is working fine with the exception of an echo/reverb effect only for user connected via RF
no issue to Echolink users
I am quite new of Allstarlink and this is my first full-duplex node
With the premises that we didnt analyse the audio yet
those are my initial observations
- i have tried to set RX audio level all the way donw from 80 to 20 without big effect to the repeater audio out and/or the echo/reverb effect
- i have rxboost and de/pre emphasis all OFF
Any help to investigate the issue , somewhere I read that having low level of RX setting can mean we are overdriving the RPi … can this cause the echo/reverb distorsion ??
Happy to produce more config files if needeed
Franco
KO4HXC
