Audio Clipping with IAXRPT / Web Transceiver Client
Good day All.
We have had our node up at VE3LSR / VE3UOR for a few months and we all have learned a lot about configuration and operation. It is ACID install and version id is 300.3.
On our asterisk system, we support three nodes:
27211 – VE3UOR UHF repeater
29133 – VE3LSR coupled through a RLC-DSP404 controller (often connected to VE3UPS and VE3UHN), and
29154 – VA3LSR remote link for VE3LSR into VE3MUS – not too active – ad-hoc RF link.
I have also been testing out iaxrpt and the WebTransceiver clients.
I am on these systems and the results have been promising. I do notice some clipping on the audio on some stations. Initially I thought it was amplitude related – over-driving the URI-FOB, but I am now beginning to suspect that it may be network related and in my research I hear the term jitter being used – which if activated, adjust operation on the receiving end only.
It may be that the system is not powered enough to drive the three uri-fobs. CPU show about 25% busy.
[root@VE3LSR etc]# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 15
model : 4
model name : Intel® Pentium® 4 CPU 3.00GHz
stepping : 3
cpu MHz : 2992.898
cache size : 2048 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 1
apicid : 0
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 5
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe lm constant_tsc pni monitor ds_cpl est cid cx16 xtpr
bogomips : 5985.79
We do think that the system is sufficiently powered.
We are looking for comments & guidance. Are we expecting too much from the system having three fobs connected? We do have good bandwidth into and out of the site.
I am listening to other systems – most not to busy, so I am not yet able to get a good reference point.
I have not dabbled with the codecs much, but have been focused on using ulaw. I am also testing with GSM – lower bandwidth.
So as I said before, thoughts or suggestions are welcome.
Keith / VA3YC
