kb0rpj
1
i have enabled the archive, the audio from when the node transmits is GREAT, but the audio when it is getting a signal is horrible.
this is NOT a problem when using echolink or any other ‘live’ audio source, it is only on the archive audio
http://204.48.104.102:8299/repeater/62225/20240723004734.WAV ← rx from repeater
http://204.48.104.102:8299/repeater/62225/20240723010153.WAV ← node transmitting
Mike
2
Can you play the raw file in something like VLC with the same result ?
You need to know if it is the node/server or a corruption in the file/not encoded correctly.
It would also be nice to know what version of ASL software you are working with.
kb0rpj
3
ASL3 , downloaded a week ago. I can get the version number if needed.
Where do I locate the raw audio files.
Other than being a little low, the audio through echolink sounds great. The audio from asl node to asl node sounds amazing.
Mike
4
kb0rpj
5
playing the WAV file in either media or vlc player sounds the same
Mike
6
Doesn’t that make you think it is the file/encoding ? Not ASL
or should I ask ‘the same as what’? It wasn’t a very exacting answer.
