My Pi has 2 IP addresses (1 from eth0 and the other from wlan0). The Wifi connection connects to an AREDN router which is in the same VLAN as other ASL nodes/servers. But I can’t get any other node on the same VLAN to connect or be able to be connected to.
This is my [nodes] stanza from the one on the Pi I’m discussing:
1100 is the one. I tried [email protected] but that just attaches to localhost. I would have thought using the IP of wlan0 (10.150.180.35) would attach ASL to that IP but it doesn’t seem to help
When I had node 1100 on it’s own dedicated Pi (with only 1 active NIC), everything worked fine. But I’m trying to consolidate things
That is correct. Each node has the appropriate [nodes] stanza(s). As I said, everything was working fine before I moved the “hub” ASL to the “shared” Pi
[general]
bindport = 4569 ; bindport and bindaddr may be specified
; NOTE: bindport must be specified BEFORE
; bindaddr or may be specified on a specific
; bindaddr if followed by colon and port
; (e.g. bindaddr=192.168.0.1:4569)
; bindaddr = 192.168.0.1 ; more than once to bind to multiple
; addresses, but the first will be the
; default
Did you look at iax.conf?
OK, let me be more “complete” Asterisk or more precisely. IAX will bind to the first interface presented, which in your case is the wired Ethernet. You have 2 choices, either change the order the interfaces come up or change the bind address in iax.conf. If you want to see this in action, disable the wired interface and try to connect to the RPi on the WiFi address.
A problem ‘might’ exist if you are operating a Pi node mobile tethered to a smartphone.
As the pi will try the next connection in your connection list on failure. Which often happens during slow tower switching events.
In this case, to save time, you would only want 1 connection described. Or you will have to wait for all the connection descriptions to time-out before the desired connection is tried again.
I used a old linksys router loaded with ddwrt and tethered it to the smartphone and a wired connection to the Pi. The wired connection is the same as the one in the house. So it only has one connection description. And is faster than using the Pi’s wifi interface.
