Asus eee PC and AllStar
Ok, so I found an Asus eee PC 4G Surf in a box in my shack, and
thought I would try it out with AllStar software. I booted up off
the USB external cd rom and started the install.
It all stops when Allstar wants to connect to the internet, but the
network port is not enabled. I cannot get passed this point.
How can I get the Asus eee to enable it's network port when booting
up? I suspect the AllStar ISO i downloaded, does not have
the drivers to get the ethernet port to fire up.
-- Yours without Wires
ZR5S
Shaun Rudling
0339400111
0826761488
Pietermaritzburg
South Africa
shaun@pmbnet.co.za
The NIC that is in mine does not have source for it in the kernel tree. To get my eee PC to work I needed to get the drivers for the network port off the net. I used Google to find it.
From: app_rpt-users-bounces@ohnosec.org [mailto:app_rpt-users-bounces@ohnosec.org] On Behalf Of Shaun
Sent: Wednesday, September 14, 2011 7:52 PM
To: app_rpt-users@ohnosec.org
Subject: [App_rpt-users] Asus eee PC and AllStar
Ok, so I found an Asus eee PC 4G Surf in a box in my shack, and thought I would try it out with AllStar software. I booted up off the USB external cd rom and started the install.
It all stops when Allstar wants to connect to the internet, but the network port is not enabled. I cannot get passed this point.
How can I get the Asus eee to enable it’s network port when booting up? I suspect the AllStar ISO i downloaded, does not have the drivers to get the ethernet port to fire up.
Yours without Wires
ZR5S
Shaun Rudling
0339400111
0826761488
Pietermaritzburg
South Africa
shaun@pmbnet.co.za
I have been able to get installs working using a Linksys USB ethernet adapter which does seem to be recognized… Then after all the updates and patching is done, if it still does not recognize the onboard NIC, go fetch the appropriate drivers for it…
I use this on a lot of newer boards that have newer NIC chips not supported in the default install library of the install disk…
Doug
KD8B
From: app_rpt-users-bounces@ohnosec.org [mailto:app_rpt-users-bounces@ohnosec.org] On Behalf Of Scott Weis
Sent: Thursday, September 15, 2011 12:49 PM
To: ‘Shaun’; app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] Asus eee PC and AllStar
Yours without Wires
ZR5S
Shaun Rudling
0339400111
0826761488
Pietermaritzburg
South Africa
shaun@pmbnet.co.za
