Lu,
I see from an earlier post that you're running a
4.19.66-v7+ kernel
version. That's the issue. You must have inadvertently
upgraded the kernel
when updating Linux.
The symptom you're describing (the /dev/dahdi folder
completely missing)
is explained by missing dahdi drivers.
The simplest solution is to down-grade your kernel to
the previous
version, which should already have drivers present.
That kernel and
supporting files are still probably installed, just
inactive.
73, David KB4FXC
On Tue, 20 Aug 2019, Lu V wrote:
> Interesting discovery. My /dev/dahdi directory is
completely missing.
I’m beginning to wonder if my sd card is in trouble.
I thought I might try to copy that directory from
another working image but it won’t let me.
Sent from my iPhone, Lu Vencl
> On Aug 19, 2019, at 4:39 PM, David McGough <kb4fxc@inttek.net >
wrote:
> Hi Lu,
> I'm not maintaining that code, so I'm not sure
where the latest ASL
> version is. I guess it's here: [https://github.com/AllStarLink/DAHDI](https://github.com/AllStarLink/DAHDI)
> What is the kernel version you're running, at
this point?? You can find
> this by going to a bash shell prompt and typing:
> cat /proc/version
> 73, David KB4FXC
>> On Mon, 19 Aug 2019, Lu V wrote:
>> Can you offer me some direction as to how I
can build dahdi from the sources?
>> Thanks
>>> On Aug 19, 2019, at 12:47 PM, JJC <cummingsj@gmail.com >
wrote:
>>> You can also build dahdi from the
sources, this is what I do so that I can have the
benefit of an updated and more secure and reliable
kernel
>>> Sent from the iRoad
>>>> On Aug 19, 2019, at 10:26, David
McGough, KB4FXC <kb4fxc@gmail.com >
wrote:
>>>> Looks like the dahdi kernel module
isn’t loading. Did the kernel get updated? If so,
revert back to the old kernel or recompile dahdi.
>>>> 73, David KB4FXC
>>>>> On Mon, Aug 19, 2019 at 11:40 AM
Lu V <luvencl8@gmail.com >
wrote:
>>>>> Well this is the first this has
happened to me on a pi install.
>>>>> I had replaced a router and
needed to restart my node. I used shutdown -r now
command and now asterisks will not start.
>>>>> I get:
>>>>> Unable to connect to remote
asterisk (does /var/run/asterisk.ctl exist?)
>>>>> root@repeater:/home/repeater#
>>>>> So if I execute with asterisk
-vvvvvvc I get this output. See attached file.
>>>>> Can someone advise what might be
happening before I give up and reimage this node?
>>>>> Thanks.
>>>>> Lu
>>>>> KA4EPS
>>>>> App_rpt-users mailing list
>>>>> App_rpt-users@lists.allstarlink.org
>>>>> [http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
>>>>> To unsubscribe from this list
please visit http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users
and scroll down to the bottom of the page. Enter your
email address and press the “Unsubscribe or edit
options button”
>>>>> You do not need a password to
unsubscribe, you can do it via email confirmation. If
you have trouble unsubscribing, please send a message
to the list detailing the problem.
>>>> To unsubscribe from this list please
options button”
options button”
> To unsubscribe from this list please visit [http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
options button”
> You do not need a password to unsubscribe, you
can do it via email confirmation. If you have trouble
unsubscribing, please send a message to the list
options button”
You do not need a password to unsubscribe, you can do
options button”
