I am trying to make a minimum system - simpleusb and cut down on both memory usage and cpu usage. Does reducing the number of asterisk modules that are loaded significantly decrease system load or decrease it at all? I suspect certain modules depend on others. Has anyone cut down on the number of loaded modules? Here is what I have loaded. Some of these applications I would never use on a minimum system.
Module Description Use Count
res_monitor.so Call Monitoring Resource 0
res_musiconhold.so Music On Hold Resource 0
res_speech.so Generic Speech Recognition API 0
res_features.so Call Features Resource 0
res_agi.so Asterisk Gateway Interface (AGI) 0
res_indications.so Indications Resource 0
res_crypto.so Cryptographic Digital Signatures 0
res_odbc.so ODBC Resource 0
res_smdi.so Simplified Message Desk Interface (SMDI) 0
res_config_odbc.so ODBC Configuration 0
res_adsi.so ADSI Resource 0
app_mp3.so Silly MP3 Application 0
pbx_config.so Text Extension Configuration 0
func_channel.so Channel information dialplan function 0
chan_iax2.so Inter Asterisk eXchange (Ver 2) 2
format_wav_gsm.so Microsoft WAV format (Proprietary GSM) 0
app_privacy.so Require phone number to be entered, if n 0
func_enum.so ENUM related dialplan functions 0
chan_tlb.so TheLinkBox channel driver 0
format_g723.so G.723.1 Simple Timestamp File Format 0
format_pcm.so Raw/Sun uLaw/ALaw 8KHz (PCM,PCMA,AU), G. 0
func_moh.so Music-on-hold dialplan function 0
app_milliwatt.so Digital Milliwatt (mu-law) Test Applicat 0
pbx_realtime.so Realtime Switch 0
codec_adpcm.so Adaptive Differential PCM Coder/Decoder 0
func_db.so Database (astdb) related dialplan functi 0
app_queue.so True Call Queueing 0
cdr_manager.so Asterisk Manager Interface CDR Backend 0
app_adsiprog.so Asterisk ADSI Programming Application 0
app_image.so Image Transmission Application 0
func_cut.so Cut out information from a string 0
app_sendtext.so Send Text Applications 0
app_disa.so DISA (Direct Inward System Access) Appli 0
app_alarmreceiver.so Alarm Receiver for Asterisk 0
app_test.so Interface Test Application 0
app_externalivr.so External IVR Interface Application 0
app_url.so Send URL Applications 0
func_sha1.so SHA-1 computation dialplan function 0
app_senddtmf.so Send DTMF digits Application 0
codec_a_mu.so A-law and Mulaw direct Coder/Decoder 0
app_waitforring.so Waits until first ring after time 0
format_h264.so Raw H.264 data 0
app_record.so Trivial Record Application 0
func_strings.so String handling dialplan functions 0
chan_usbradio.so usb Console Channel Driver 0
app_hasnewvoicemail.so Indicator for whether a voice mailbox ha 0
func_global.so Global variable dialplan functions 0
app_ices.so Encode and Stream via icecast and ices 0
codec_speex.so Speex Coder/Decoder 0
app_dahdiras.so DAHDI RAS Application 0
app_cdr.so Tell Asterisk to not maintain a CDR for 0
app_festival.so Simple Festival Interface 0
app_dumpchan.so Dump Info About The Calling Channel 0
app_userevent.so Custom User Event Application 0
func_odbc.so ODBC lookups 0
app_echo.so Simple Echo Application 0
app_speech_utils.so Dialplan Speech Applications 0
func_base64.so base64 encode/decode dialplan functions 0
format_sln.so Raw Signed Linear Audio support (SLN) 0
app_lookupblacklist.so Look up Caller*ID name/number from black 0
codec_dahdi.so Generic DAHDI Transcoder Codec Translato 0
func_env.so Environment/filesystem dialplan function 0
chan_beagle.so Beagleboard Radio Interface Channel Driv 0
chan_simpleusb.so simple usb Radio Interface Channel Drive 1
app_voicemail.so Comedian Mail (Voicemail System) 0
chan_usrp.so USRP Channel Module 0
app_lookupcidname.so Look up CallerID Name from local databas 0
app_stack.so Stack Routines 0
cdr_odbc.so ODBC CDR Backend 0
app_zapateller.so Block Telemarketers with Special Informa 0
app_waitforsilence.so Wait For Silence 0
format_jpeg.so JPEG (Joint Picture Experts Group) Image 0
app_parkandannounce.so Call Parking and Announce Application 0
app_meetme.so MeetMe conference bridge 0
app_settransfercapability.so Set ISDN Transfer Capability 0
app_dahdibarge.so Barge in on channel application 0
app_controlplayback.so Control Playback Application 0
app_morsecode.so Morse code 0
app_talkdetect.so Playback with Talk Detection 0
app_amd.so Answering Machine Detection Application 0
codec_ulaw.so mu-Law Coder/Decoder 2
app_directory.so Extension Directory 0
func_cdr.so CDR dialplan function 0
app_nbscat.so Silly NBS Stream Application 0
app_authenticate.so Authentication Application 0
func_realtime.so Read/Write values from a RealTime reposi 0
app_softhangup.so Hangs up the requested channel 0
func_groupcount.so Channel group dialplan functions 0
app_mixmonitor.so Mixed Audio Monitoring Application 0
app_forkcdr.so Fork The CDR into 2 separate entities 0
func_math.so Mathematical dialplan function 0
app_rpt.so Radio Repeater/Remote Base Application 0
func_uri.so URI encode/decode dialplan functions 0
app_verbose.so Send verbose output 0
codec_gsm.so GSM Coder/Decoder 0
app_exec.so Executes dialplan applications 0
app_chanspy.so Listen to the audio of an active channel 0
app_macro.so Extension Macros 0
app_playback.so Sound File Playback Application 0
app_followme.so Find-Me/Follow-Me Application 0
format_ilbc.so Raw iLBC data 0
cdr_csv.so Comma Separated Values CDR Backend 0
format_vox.so Dialogic VOX (ADPCM) File Format 0
app_radbridge.so Radio Bridging interface module 0
chan_echolink.so echolink channel driver 0
app_realtime.so Realtime Data Lookup/Rewrite 0
codec_g726.so ITU G.726-32kbps G726 Transcoder 2
app_transfer.so Transfer 0
app_dahdiscan.so Scan Zap channels application 0
format_gsm.so Raw GSM data 0
format_g729.so Raw G729 data 0
pbx_loopback.so Loopback Switch 0
func_callerid.so Caller ID related dialplan function 0
pbx_spool.so Outgoing Spool Support 0
app_directed_pickup.so Directed Call Pickup Application 0
app_dial.so Dialing Application 0
chan_agent.so Agent Proxy Channel 0
func_language.so Channel language dialplan function 0
chan_sip.so Session Initiation Protocol (SIP) 0
codec_alaw.so A-law Coder/Decoder 0
app_while.so While Loops and Conditional Execution 0
func_logic.so Logical dialplan functions 0
chan_voter.so radio Voter channel driver 0
func_md5.so MD5 digest dialplan functions 0
app_flash.so Flash channel application 0
app_getcpeid.so Get ADSI CPE ID 0
cdr_custom.so Customizable Comma Separated Values CDR 0
app_page.so Page Multiple Phones 0
func_timeout.so Channel timeout dialplan functions 0
app_gps.so GPS interface module 0
app_readfile.so Stores output of file into a variable 0
app_random.so Random goto 0
format_g726.so Raw G.726 (16/24/32/40kbps) data 0
format_h263.so Raw H.263 data 0
pbx_dundi.so Distributed Universal Number Discovery ( 0
app_db.so Database Access Functions 0
res_convert.so File format conversion CLI command 0
func_rand.so Random number dialplan function 0
app_setcallerid.so Set CallerID Application 0
app_read.so Read Variable Application 0
chan_dahdi.so DAHDI Telephony 8
app_channelredirect.so Channel Redirect 0
app_system.so Generic System() application 0
app_sms.so SMS/PSTN handler 0
pbx_ael.so Asterisk Extension Language Compiler 0
app_setcdruserfield.so CDR user field apps 0
format_wav.so Microsoft WAV format (8000Hz Signed Line 0
app_sayunixtime.so Say time 0
app_chanisavail.so Check channel availability 0
res_clioriginate.so Call origination from the CLI 0
app_dictate.so Virtual Dictation Machine 0
chan_local.so Local Proxy Channel (Note: used internal 0
152 modules loaded
73 Doug
WA3DSP
