hi @Mike & @N8EI , thanks for your response,
I am using Asterisk 16, and dahdi 3.1.0
and
the following is my rpt.conf ; i have my rxchannel mentioned in [610], please suggest changes if are required.
[610]
rxchannel = Radio/usb_610
context = Radio_1
callerid = “610”
duplex = 1
linktolink = no
linkmongain = 0
erxgain = -3
etxgain = 3
scheduler = schedule
functions = functions
phone_functions = functions
link_functions = functions
callonvox = 0
ivoxcontext = Radio_1
ivoxexten = s
telemetry = telemetry
morse = morse
wait_times = wait-times
accountcode = RADIO
hangtime = 5000
althangtime = 4000
totime = 180000
idrecording = |iWA4XYZ
idtalkover = |iWA4XYZ
idtime = 540000
politeid = 30000
unlinkedct = ct2
remotect = ct3
linkunkeyct = ct8
holdofftelem = 0
telemdefault = 1
telemdynamic = 1
[functions]
1 = ilink,1 ; Disconnect specified link
2 = ilink,2 ; Connect specified link – monitor only
3 = ilink,3 ; Connect specified link – tranceive
4 = ilink,4 ; Enter command mode on specified link
70 = ilink,5 ; System status
99 = cop,6 ; PTT (phone mode only)
; Macro Commands
5 = macro
; Autopatch Commands
61 = autopatchup,noct = 1,farenddisconnect = 1,dialtime = 20000,context=Radio_1,quiet = 1 ; Autopatch up
62 = autopatchdn ; Autopatch down
; Status Commands
721 = status,1 ; Force ID (global)
722 = status,2 ; Give Time of Day (global)
723 = status,3 ; Give software Version (global)
724 = status,4 ; Give GPS location info
725 = status,5 ; Last (dtmf) user
711 = status,11 ; Force ID (local only)
712 = status,12 ; Give Time of Day (local only)
; Link Commands
806 = ilink,6 ; Disconnect all links
807 = ilink,7 ; Last Node to Key Up
808 = ilink,8 ; Connect specified link – local monitor only
809 = ilink,9,1999,“Testing” ; would send a text message to node 1999 replace 1999 with 0 for all connected nodes
810 = ilink,10 ; Disconnect all RANGER links (except permalinks)
811 = ilink,11 ; Disconnect a previously permanently connected link
812 = ilink,12 ; Permanently connect specified link – monitor only
813 = ilink,13 ; Permanently connect specified link – tranceive
815 = ilink,15 ; Full system status (all nodes)
816 = ilink,16 ; Reconnect links disconnected with “disconnect all links”
817 = ilink,17 ; MDC test (for diag purposes)
818 = ilink 18 ; Permanently Connect specified link – local monitor only
; Control operator (cop) functions. Change these to something other than these codes listed below!
901 = cop,1 ; System warm boot
902 = cop,2 ; System enable
903 = cop,3 ; System disable
904 = cop,4 ; Test tone on/off (toggle)
905 = cop,5 ; Dump system variables on console (debug use only)
907 = cop,7 ; Time out timer enable
908 = cop,8 ; Time out timer disable
909 = cop,9 ; Autopatch enable
910 = cop,10 ; Autopatch disable
911 = cop,11 ; User linking functions enable
912 = cop,12 ; User linking functions disable
913 = cop,13 ; Query system control state
914 = cop,14 ; Set system control state
915 = cop,15 ; Scheduler enable
916 = cop,16 ; Scheduler disable
917 = cop,17 ; User functions enable (time, id, etc)
918 = cop,18 ; User functions disable
919 = cop,19 ; Select alternate hang time (althangtime)
920 = cop,20 ; Select standard hangtime (hangtime)
921 = cop,21 ; Enable Parrot Mode
922 = cop,22 ; Disable Parrot Mode
923 = cop,23 ; Birdbath (Current Parrot Cleanup/Flush)
924 = cop,24 ; Flush all telemetry
925 = cop,25 ; Query last node un-keyed
926 = cop,26 ; Query all nodes keyed/unkeyed
927 = cop,27 ; Reset DAQ minimum on a pin
928 = cop,28 ; Reset DAQ maximum on a pin
930 = cop,30 ; Recall Memory Setting in Attached Xcvr
931 = cop,31 ; Channel Selector for Parallel Programmed Xcvr
932 = cop,32 ; Touchtone pad test: command + Digit string + # to playback all digits pressed
933 = cop,33 ; Local Telemetry Output Enable
934 = cop,34 ; Local Telemetry Output Disable
935 = cop,35 ; Local Telemetry Output on Demand
936 = cop,36 ; Foreign Link Local Output Path Enable
937 = cop,37 ; Foreign Link Local Output Path Disable
938 = cop,38 ; Foreign Link Local Output Path Follows Local Telemetry
939 = cop,39 ; Foreign Link Local Output Path on Demand
942 = cop,42 ; Echolink announce node # only
943 = cop,43 ; Echolink announce node Callsign only
944 = cop,44 ; Echolink announce node # & Callsign
945 = cop,45 ; Link Activity timer enable
945 = cop,46 ; Link Activity timer disable
947 = cop,47 ; Reset “Link Config Changed” Flag
948 = cop,48 ; Send Page Tone (Tone specs separated by parenthesis)
949 = cop,49 ; Disable incoming connections (control state noice)
950 = cop,50 ; Enable incoming connections (control state noicd)
951 = cop,51 ; Enable sleep mode
952 = cop,52 ; Disable sleep mode
953 = cop,53 ; Wake up from sleep
954 = cop,54 ; Go to sleep
955 = cop,55 ; Parrot Once if parrot mode is disabled
956 = cop,56 ; Rx CTCSS Enable
957 = cop,57 ; Rx CTCSS Disable
958 = cop.58 ; Tx CTCSS On Input only Enable
959 = cop,59 ; Tx CTCSS On Input only Disable
960 = cop,60 ; Send MDC-1200 Burst (cop,60,type,UnitID[,DestID,SubCode])
; Type is ‘I’ for PttID, ‘E’ for Emergency, and ‘C’ for Call
; (SelCall or Alert), or ‘SX’ for STS (ststus), where X is 0-F.
; DestID and subcode are only specified for the ‘C’ type message.
; UnitID is the local systems UnitID. DestID is the MDC1200 ID of
; the radio being called, and the subcodes are as follows:
; Subcode ‘8205’ is Voice Selective Call for Spectra (‘Call’)
; Subcode ‘8015’ is Voice Selective Call for Maxtrac (‘SC’) or
; Astro-Saber(‘Call’)
; Subcode ‘810D’ is Call Alert (like Maxtrac ‘CA’)
961 = cop,61 ; Send Message to USB to control GPIO pins (cop,61,GPIO1=0[,GPIO4=1]…)
962 = cop,62 ; Send Message to USB to control GPIO pins, quietly (cop,62,GPIO1=0[,GPIO4=1]…)
963 = cop,63 ; Send pre-configred APRSTT notification (cop,63,CALL[,OVERLAYCHR])
964 = cop,64 ; Send pre-configred APRSTT notification, quietly (cop,64,CALL[,OVERLAYCHR])
965 = cop,65 ; Send POCSAG page (equipped channel types only)
[functions-remote]
0 = remote,1 ; Retrieve Memory
1 = remote,2 ; Set freq.
2 = remote,3 ; Set tx PL tone
3 = remote,4 ; Set rx PL tone
40 = remote,100 ; Rx PL off
41 = remote,101 ; Rx PL on
42 = remote,102 ; Tx PL off
43 = remote,103 ; Tx PL on
44 = remote,104 ; Low Power
45 = remote,105 ; Medium Power
46 = remote,106 ; High Power
711 = remote,107 ; Bump -20
714 = remote,108 ; Bump -100
717 = remote,109 ; Bump -500
713 = remote,110 ; Bump +20
716 = remote,111 ; Bump +100
719 = remote,112 ; Bump +500
721 = remote,113 ; Scan - slow
724 = remote,114 ; Scan - quick
727 = remote,115 ; Scan - fast
723 = remote,116 ; Scan + slow
726 = remote,117 ; Scan + quick
729 = remote,118 ; Scan + fast
79 = remote,119 ; Tune
51 = remote,5 ; Long status query
52 = remote,140 ; Short status query
67 = remote,210 ; Send a *
69 = remote,211 ; Send a #
85 = cop,6 ; Remote base telephone key
[telemetry]
ct1 = |t(350,0,100,2048)(500,0,100,2048)(660,0,100,2048)
ct2 = |t(660,880,150,2048)
ct3 = |t(440,0,150,4096)
ct4 = |t(550,0,150,2048)
ct5 = |t(660,0,150,2048)
ct6 = |t(880,0,150,2048)
ct7 = |t(660,440,150,2048)
ct8 = |t(700,1100,150,2048)
ranger = |t(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,50,0)(1800,0,60,3072)(0,0,150,0)
remotemon = |t(1209,0,50,2048) ; local courtesy tone when receive only
remotetx = |t(1633,0,50,3000)(0,0,80,0)(1209,0,50,3000) ; local courtesy tone when linked Trancieve mode
cmdmode = |t(900,903,200,2048)
functcomplete = |t(1000,0,100,2048)(0,0,100,0)(1000,0,100,2048)
remcomplete = |t(650,0,100,2048)(0,0,100,0)(650,0,100,2048)(0,0,100,0)(650,0,100,2048)
pfxtone = |t(350,440,30000,3072)
patchup = rpt/callproceeding
patchdown = rpt/callterminated
[morse]
speed = 20 ; Approximate speed in WPM
frequency = 800 ; Morse Telemetry Frequency
amplitude = 4096 ; Morse Telemetry Amplitude
idfrequency = 1065 ; Morse ID Frequency
idamplitude = 1024 ; Morse ID Amplitude
[wait-times]
telemwait = 2000 ; Time to wait before sending most telemetry
idwait = 500 ; Time to wait before starting ID
unkeywait = 2000 ; Time to wait after unkey before sending CT’s and link telemetry
calltermwait = 2000 ; Time to wait before announcing “call terminated”
[nodes]
510 = radio@127.0.0.1:4569/510,NONE
[memory]
[macro]
[schedule]
