Astdb.php is missing
I can't find astdb.php in recent releases. It's a handy tool to grep info from. Has it been replaced with an alternative? I see an sqlite3 file; but that's not as easily accessed.
Tom / K5TRA
Have a look at :
and I will also add that we're looking for an alternate mechanism to provide per-node data so that your system doesn't need to repeatedly download/refresh the file.
As a work around, I put my own copy of astdb.php in my /usr/local/sbin directory. I don't need it for any other dashboard (allmon3 is fine). I only run it if I want to lookup (with grep) node data associated with a particular callsign. I also us the extnodes file to grep the IP for a particular node.
