Assistance with TM-d710 and URI-x with DIAL
I am helping a friend with a new node. He has a URI-X, Kenwood TM-d710 and DIAL.
TX audio is working fine.
RX audio is not. I have the usbradio.conf file set with carrierfrom=usb
If I change it to carrierfrom=usbinvert then I can get DTMF through and audio, but it is keyed 100% of the time and no TXAudio works.
So it seems it should be set for usb.
I tried DSP, didn’t seem to work either.
The cable between the URI-X and the d710 uses the PS2 connector and is a pre-made cable from uricables.com
I am at a loss of what else to try, should I build the loopback tester that I see in the archives?
Mike
Kb8zgl
Mike
Kb8zgl
What duplex mode are you set to in rpt.conf?
On 9/7/2016 9:53 AM, Michael J.
Wolthuis wrote:
        I am helping
a friend with a new node.� He has a URI-X, Kenwood TM-d710
and DIAL.
        TX audio is
working fine.
        RX audio is
not.� I have the usbradio.conf file set with carrierfrom=usb
        If I change
works.
        So it seems
        I tried DSP,
didn�t seem to work either.
        The cable
        I am at a
Mike
Kb8zgl
-- "Just say no to world domination"
Duplex=1 in rpt.conf
Half duplex with telemetry tones and hang time. Does not repeat audio. This mode is preferred when interfacing a simplex node.
Mike
Organization: MSGStor
Reply-To: szingman@msgstor.com
Date: Wednesday, September 7, 2016 at 1:48 PM
To: Michael Wolthuis wolthuis@gmail.com, “app_rpt-users@ohnosec.orgapp_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] Assistance with TM-d710 and URI-x with DIAL
Mike
Kb8zgl
“Just say no to world domination”
First of all the default configs are set for full duplex. (Even if
the duplex setting is not stated in RPT.conf) Since you are
connecting to a half duplex radio, you will need to set duplex =1 or
0 in rpt.conf. And set the duplex setting in simpleUSB or USBradio
to half duplex (duplex=0).
If the node is in full duplex, the moment the URI sees a signal it
will key the radio.
Also, you need to know what the logic is for the Sq on the PS 2 port
on the Kenwood.
Does the line go HI on RX or go low?
Once you have determined the cor logic, you need to know if it pulls
to ground when it goes low.
The COR and PL decode inputs on the URI need to see a signal that
transitions to ground. It doesn’t matter if its active hi or low.
The URI will never see an input signal if it it simply goes hi but
doesn’t go to ground.
If the kenwood signal doesn't go to ground then you may need to
drive an NPN transistor and connect the collector to the URI so it
sees a transition to ground.
The URI doesnt care about input voltage, it only cares if the input
was grounded or not. The COR and PL inputs are pulled up internally
and diode isolated.
also check to see if the SQ line goes active during transmit on the
Kenwood.
I had this problen on an Icom ic 208 when connected to the packet
port. the SQ line was active on receive and transmit.
I had to use DSP and the discriminator connection on the PS 2 port
to get around that.
Hope this helps
On 9/6/2016 8:20 PM, Michael J.
Wolthuis wrote:
        I am helping
and DIAL.
        TX audio is
working fine.
        RX audio is
        If I change
works.
        So it seems
        I tried DSP,
        The cable
        I am at a
Mike
Kb8zgl
