ASL3 with CM108 soundcard for an Motorola GM300 can't get PTT on card
Any thoughts on what I am doing wrong ?
I have a :
OS Kernel : 6.12.62+rpt-rpi-v8
ASL [app_rpt] : 3.7.1
the sound card is modified as per How to Modify A CM108 Sound Fob For Allstar 2. - allstar setup.com
I have a Motorola gm300 no matter what config i do i can’t get the radio to ptt the sound card i get receive from the sound card to the radio , i cant get an out ptt /core , the voltage are correct from the gm300 here is how the config is setup and i tried multiple confg and still not working
GM300 cor is active low (it does not change if i go active high)
the following is what i have for sound card configuration
I have included both the simplusb and the usbradio file below
here is the simpelusb.config:
;! Automatically generated configuration file
;! Filename: simpleusb.conf (/etc/asterisk/simpleusb.conf)
;! Generator: chan_simpleusb
;! Creation Date: Sat Jan 31 12:19:07 2026
;******** Template-tized simpleusb.conf ********
; Note to editors: set tabs to 4 space characters. No wrap to keep comments neat.
; vim: tabstop=4
; SimpleUSB channel driver Configuration File
; See simpleusb.conf - AllStarLink Manual for full option documentation.
;;;;; New to ASL3 ;;;;;
;;;;; The SimpleUSB "tune" settings have moved to ;;;;;
;;;;; this file. The simpleusb_tune_usb_1999.conf ;;;;;
;;;;; file is no longer used. ;;;;;
; If you are going to use this channel driver, you MUST enable it in modules.conf
; change:
; noload => chan_simpleusb.so ; CM1xx USB Cards with Radio Interface Channel Driver (No DSP)
; noload => res_usbradio.so ; Required for both simpleusb and usbradio
; to:
; load => chan_simpleusb.so ; CM1xx USB Cards with Radio Interface Channel Driver (No DSP)
; load => res_usbradio.so ; Required for both simpleusb and usbradio
[general]
;------------------------------ JITTER BUFFER CONFIGURATION --------------------------
; jbenable = yes ; Enables the use of a jitterbuffer on the receiving side of an
; simpleusb channel. Defaults to "no". An enabled jitterbuffer will
; be used only if the sending side can create and the receiving
; side can not accept jitter. The simpleusb channel can't accept jitter,
; thus an enabled jitterbuffer on the receive simpleusb side will always
; be used if the sending side can create jitter.
; jbmaxsize = 200 ; Max length of the jitterbuffer in milliseconds.
; jbresyncthreshold = 1000 ; Jump in the frame timestamps over which the jitterbuffer is
; resynchronized. Useful to improve the quality of the voice, with
; big jumps in/broken timestamps, usually sent from exotic devices
; and programs. Defaults to 1000.
; jbimpl = fixed ; Jitterbuffer implementation, used on the receiving side of an simpleusb
; channel. Two implementations are currently available - "fixed"
; (with size always equals to jbmax-size) and "adaptive" (with
; variable size, actually the new jb of IAX2). Defaults to fixed.
; jblog = no ; Enables jitterbuffer frame logging. Defaults to "no".
node-main
;;;;; Template for all your SimpleUSB nodes ;;;;;
; 0 = no (radio interface does not have an EEPROM)
; 1 = yes (default)
hdwtype = 0 ; Leave this set to 0 for USB sound fobs designed for app_rpt
; or modified cmxxx sound fobs.
; 2 is for NHC interfaces.
; 3 is for a custom interface.
; Receiver parameters
rxboost = no ; no = 20db attenuator inserted, yes = 20db attenuator removed
; Set to yes for additional gain if using a low-level receiver output
; CM119B devices are hard coded to rxboost 20dB attenuator removed
carrierfrom = usbinvert ; no,usb,usbinvert
; usb - from the COR line on the USB sound fob (Active high)
; usbinvert - from the inverted COR line on the USB sound fob (Active low)
; pp - from parallel port (Active high)
; ppinvert - from the inverted parallel port (Active low)
ctcssfrom = no ; no,usb,usbinvert
; usb - CTCSS decoding using input from USB sound fob (Active high)
; usbinvert - from the inverted CTCSS line on the USB sound fob (Active low)
deemphasis = no ; enable de-emphasis (input from discriminator)
plfilter = yes ; enable PL filter
rxondelay = 0 ; Number of 20ms audio frames to delay after the hardware COR goes active,
; before the signal is considered valid and COR is asserted to app_rpt.
; If txoffdelay is also set (non-zero), then the transmitter has to be off
; for txoffdelay AND COR has to be active for rxondelay before COR is
; asserted to app_rpt. The default is 0. Use this ONLY on simplex nodes,
; to eliminate "Ping Ponging". Leave commented out for repeaters or
; other full duplex nodes.
txoffdelay = 0 ; Number of 20ms audio frames the transmitter has to be un-keyed before a
; hardware COR signal is considered valid, and COR is asserted to app_rpt.
; If rxondelay is also set (non-zero), then the transmitter has to be off
; asserted to app_rpt. The default is 0. Leave commented out for normal
; repeaters or other full duplex nodes.
; This is useful when setting up a half-duplex link with an existing
; repeater, where you need to ignore the repeater's hangtime.
; Transmitter parameters
invertptt = no ; Invert PTT: no,yes
; no - ground to transmit
; yes - open to transmit
preemphasis = no ; Perform standard 6db/octave pre-emphasis
; pager = no ; no,a,b (e.g. pager = b means "put the normal repeat audio on channel A, and the pager audio on channel B")
; duplex3 = 0 ; duplex 3 gain setting (0 to disable)
clipledgpio = 0 ; Enable ADC Clip Detect feature to use a GPIO output (0 to disable).
; Supports URI Clip LED by setting a GPIO (if available) high for 500mS
; when clipping detected. Value = GPIO# to use (GPIO1 recommended)
legacyaudioscaling = no ; If yes, continue to do raw audio sample scaling and clipping, resulting in Tx audio levels increasing
;;; End of node-main template
#tryinclude "custom/simpleusb.conf"
#tryinclude "custom/simpleusb/*.conf"
;;;;;;;;;;;;;;;; Configure your nodes here ;;;;;;;;;;;;;;;;
; Note: there is no need to duplicate entire settings. Only
; place settings that are different than the template.
; Note: the device string is automatically found when the
; USB setting "devstr=" is empty.
; Note: the interface "tune" settings will be added to the
; per-node settings (below).
621450
;;;;; ASL3 Tune settings ;;;;;
devstr =
rxmixerset = 500
txmixaset = 500
txmixbset = 500
ctcssfrom = no
Usbradio.conf:
GNU nano 8.4 /etc/asterisk/usbradio.conf
;******** Template-tized usbradio.conf ********
; vim: tabstop=4
; USBRadio channel driver Configuration File
;;;;; The USBRadio "tune" settings have moved to ;;;;;
;;;;; this file. The usbradio_tune_usb_1999.conf ;;;;;
; noload => chan_usbradio.so ; CM1xx USB Cards with Radio Interface Channel Driver (DSP)
; to:
; load => chan_usbradio.so ; CM1xx USB Cards with Radio Interface Channel Driver (DSP)
[general]
; USBRADIO channel. Defaults to "no". An enabled jitterbuffer will
; side can not accept jitter. The USBRADIO channel can't accept jitter,
; thus an enabled jitterbuffer on the receive USBRADIO side will always
; jbimpl = fixed ; Jitterbuffer implementation, used on the receiving side of an USBRADIO
node-main
;;;;; Template for all your USBRadio nodes ;;;;;
; 0 = no (default)
; 1 = yes
hdwtype = 0 ; Leave this set to 0 for USB sound fobs modified using
rxboost = yes ; no - 20db attenuator inserted
; yes - 20db attenuator removed
rxctcssrelax = 1 ; reduce talkoff from radios w/o CTCSS TX HPF
rxsqhyst = 3000 ; Setting Squelch Hysteresis
; 3000 is the default amount.
; An amount of 500 seems good.
; Then set the squelch to the highest number revealed when doing a "radio
; tune rxsquelch" - running the command multiple (like 20) times in a row.
txctcssdefault = 100.0 ; default TX CTCSS frequency, any frequency permitted
rxctcssfreqs = 100.0,91.5 ; RX CTCSS frequencies list in floating point. must be in table
txctcssfreqs = 100.0,91.5 ; TX CTCSS frequencies list. any frequency permitted. will follow RX CTCSS frequency
rxctcssoverride = no ; Set to yes to start out in carrier squelch mode
carrierfrom = usb ; no,usb,usbinvert,dsp,vox
; dsp - from RX noise using DSP techniques
; vox - voice activated from RX audio
voxhangtime = 2000 ; If carrierfrom=vox, mS to wait detecting RX audio before setting rxcarrierdetect=0
; 2000 is the default but results in 2 seconds of silence added after RX unkey.
; 500 seems more optimal. Lower values may result in unintended drops in RX CD.
ctcssfrom = no ; no,usb,usbinvert,dsp
; no - no CTCSS decoding, system will be carrier squelch
; usb - from the CTCSS line on the USB sound fob (Active high)
; dsp - CTCSS decoding using RX audio in DSP.
; rxdemod option must be set to flat for this to work.
rxdemod = flat ; input type from radio: no,speaker,flat
; flat - Use RX audio from discriminator (before de-emphasis)
rxsquelchdelay = 30 ; delayline in ms carrier squelch tail eliminator
rxondelay = 0 ; Number of 20mSec intervals following the release of PTT.
; Uncomment and/or adjust for simplex nodes to eliminate "Ping Ponging"
; or "Relay Racing". A positive value here will instruct the usbradio
; driver to ignore the COR line for a specified number of 20mSec
; intervals following the release of PTT. Use this ONLY on simplex
; nodes, and leave commented out for repeaters or other full duplex nodes.
txoffdelay = 0 ; Ignore the receiver for a specified number of 20 millisecond
; intervals after the transmitter unkeys.
txboost = no ; Add transmitter audio gain boost: no,yes
txprelim = yes ; Audio processing on left output channel: no,yes
; no - Audio is not pre-emphasized and limited.
; (suitable for use on a microphone input)
; yes - Audio is pre-emphasized and limited.
; (suitable for direct connection to an FM modulator)
txlimonly = yes ; Audio limiting with no pre-emphasis on output channel: no,yes
; no - Audio is not limited.
txtoctype = notone ; Transmit tone control type: no,phase,notone
; phase - encode CTCSS and reverse phase before unkeying TX (AKA "reverse burst")
; notone - encode CTCSS and stop sending tone before unkeying TX (AKA "chicken burst")
txmixa = composite ; Left channel output: no,voice,tone,composite,auxvoice
; no - Do not output anything
; voice - output voice only
; tone - CTCSS tone only
; composite - voice and tone
; auxvoice - auxiliary voice output at headphone level for monitoring
txmixb = no ; Right channel output: no,voice,tone,composite, auxvoice
; Audio filters
rxlpf = 0 ; Receiver Audio Low Pass Filter 0,1 2
; 0 - 3.0 kHz cutoff (Default) value for reduced noise and increased intelligibility.
; 1 - 3.3 kHz cutoff for increased high end, sibilance and brightness.
; 2 - 3.5 kHz cutoff for even more high end, sibilance and brightness.
rxhpf = 0 ; Receiver Audio High Pass Filter 0,1
; 0 - 300 Hz cutoff. (Default) value to reduce sub-audible signals for retransmission and in the receiver speaker.
; 1 - 250 Hz cutoff for additional received and retransmitted bass response.
; recommend using this filter with a CTCSS tone no higher than 186.2 Hz.
txlpf = 0 ; Transmitter Audio Low Pass Filter 0,1
; 0 - 3.0 kHz cutoff. (Default) value.
txhpf = 0 ; Transmitter Audio High Pass Filter 0,1,2
; 0 - 300 Hz cutoff. (Default) value to reduce interference between voice and sub-audible signaling tones and codes.
; 1 - 250 Hz cutoff for increased bass response in transmitted audio.
; 2 - 120 Hz cutoff for special applications requiring additional bass response in transmitted audio.
; Not recommended due to the increased possibility of voice energy interfering with sub-audible signaling
duplex = 1 ; Duplex 0,1
; 0 - half duplex
; 1 - full duplex
duplex3 = 0 ; duplex 3 gain setting (0 to disable) ???
; by 0.83dB and Rx audio levels decreasing by 1.94dB. Should be set to no unless you have an existing
; node with precisely adjusted audio levels and are unable to adjust them. This parameter and associated
; scaling/clipping code will be deleted once existing installs have been able to verify their audio levels
#tryinclude "custom/usbradio.conf"
#tryinclude "custom/usbradio/*.conf"
621450
devstr=
rxmixerset=500
txmixaset=500
txmixbset=500
rxvoiceadj=0.5
txctcssadj=200
rxsquelchadj=500
Make sure that in your RSS you've configured the signal line you're using to be the combined COR + CTCSS signal setting. If you have it set active low, then carrierfrom needs to be usbinvert.
ok i have carrierfrom = usbinvert and ctcssfrom = usbinvert the radio is set to active low on pin 8 cor
no matter what i try the cor on the terminal is not turning to keyed it always at high =3 volts for it to work it need to pull down to ground
thanks
GV
Right, that's what I'm saying. By default, a Maxtrac/Radius/GM doesn't have COR/CTCSS signalling on the aux port at all. You have to program the pin with the RSS software for that version of the GM300.
sorry it is pin 8 out of the 16 pin it has
pd/dpl & CSQ Det out put denounce no active level high or (low)
the sound card is at level 3.4 volts and when keys it goes down to 2,4 volts
i dont understand why this is so difficult to get working its been several months
But did you program pin 8 in RSS to be that? By default, that is NOT what pin 8 is programmed to. In the Motorola RSS you have to set it to the COR + PL logic state and set it active=low. You also need to make sure that you have the "mic hangup" option disabled in the wide menu (or make a RJ-45 mic jumper on pins 3-4). A GM300 won't work "out of the box" for ASL. You have to program it the right way or you have to know someone else did.
yes i did see picture its set to high as i am experiencing or low it still don’t work
and i have a connection from pin 3 and 4 in the microphone jack for the off hook
Based on that RSS screenshot then you want carrierfrom=usb since it's active high. But if the voltage isn't going high on a true receive, that almost sounds like the hang up switch is still in play. I assume you've make sure the GM300 and the Pi/USB have the same ground right?
i have a rj45 in the mic plug for the off hook mic , no matter what i do, the COS input is not keyed but the ptt is , when i look at the tune interface cli with the view of cos,ptt etc.. yes i have one source of power for all cards and units so same ground .
thanks
GV
more info
when the gm300 is reciving a signal the soundcard activate ptt out and the cos out remains clear and the ctss input is always off and the cos input is always clear
The COS input needs to be keyed to work and this is my issue it never dose
I don't understand where you're claiming the GM300 is receiving a signal and it's activating the sound card's PTT. That's fundamentally impossible unless you're operating in a duplex mode. And even then, COS would still be active in tandem. If COS is never being active high, that's a radio hardware problem or a cabling issue between the radio and the sound card.
good evening
I think i have it now here is what i found:
1- in the node settings the duplex type was set to 2 i set it to 0
2- after 3 gm300 and blew one up i finally got one that the audio was properly working the original radio the spkr out audio was not passing thru
4- on the sound card between the c2 and cor i added a bat43 diode and the cor started working and putting the ptt to active low in the config file also
5- added a 40k resistor in line with the tx audio fixed the audio issues
so your last message helped me by changing the duplex, thanks for the help the parrot is working good
really appreciated it
Ve2gfv
