OS Kernel : 6.1.0-44-cloud-amd64
Asterisk : 22.8.2+asl3-3.8.3-1.deb12
ASL [app_rpt] : 3.8.3
Installed ASL packages :
Package Version
asl-apt-repos 1.4-1.deb12
asl3 3.17-1.deb12
asl3-asterisk 2:22.8.2+asl3-3.8.3-1.deb12
asl3-asterisk-config 2:22.8.2+asl3-3.8.3-1.deb12
asl3-asterisk-modules 2:22.8.2+asl3-3.8.3-1.deb12
asl3-menu 1.18-1.deb12
dahdi 1:3.1.0-2
dahdi-linux 1:3.4.0-11.asl.deb12
Inquiry
After updating to asl3 2.22.8.2 our transmit voter will not key the repeater. I'm seeing events in the asterisk cli after keying up, but the audio will not transmit over the repeater. The audio is being received as I'm able to hear audio on echolink.
Troubleshooting steps
- Reinstall all ASL3 related packages
- Downgrade ASL packages to earlier release
- Start a fresh VM using debian 12 bookworm, install all latest ASL3 packages.
- Re-point both RTCM clients to the new server.
- Verify RTCM clients talking with voter ASL3 VM
- Verify chan_voter loaded in modules.conf
- verify both voters are showing up in the asterisk cli using the Voter Instance command. The output of the command is below
Voter Instance <REDACTED> Display: CgrK |=======================================================>| [255] CgrE |> | [ 0] Active Clients: CgrK -- <SOMEIP1>:1667 CgrE -- <SOMEIP2>:1667
CLI messages while keying up repeaster, but no audio
Connected to Asterisk 22.8.2+asl3-3.8.3-1.deb12 currently running on asl3 (pid = 9910) -- Channel voter/564560: TX On -- Channel Announcer/Telemetry-0000000a;2 joined 'softmix' base-bridge <9cb5b3b0-461e-482c-a408-54bce3a3adaa> -- Channel Announcer/Telemetry-0000000a;2 left 'softmix' base-bridge <9cb5b3b0-461e-482c-a408-54bce3a3adaa> -- Channel voter/564560: TX Off asl3*CLI> - If I put the RTCM client in diagnostics mode from the firmware telnet menu, I'm able to hear the repeater transmitter key up and hear the test tones from diagnostics. So the repeater and RTCM equipment is properly configured and connected
- RTCM and allstar will work if I use my old ASL VM. Info about the old ASL setup below.
OS : Debian GNU/Linux 12 (bookworm) OS Kernel : 6.1.0-37-amd64 Asterisk : 22.2.0+asl3-3.4.5-1.deb12 ASL [app_rpt] : Installed ASL packages : Package Version ============================== ============================== allmon3 1.4.2-1.deb12 asl3 3.7.1-1.deb asl3-asterisk 2:22.2.0+asl3-3.4.5-1.deb12 asl3-asterisk-config 2:22.2.0+asl3-3.4.5-1.deb12 asl3-asterisk-modules 2:22.2.0+asl3-3.4.5-1.deb12 asl3-menu 1.13-1.deb12 asl3-tts 1.0.1-1.deb12 cockpit 287.1-0+deb12u3 cockpit-bridge 287.1-0+deb12u3 cockpit-networkmanager 287.1-0+deb12u3 cockpit-packagekit 287.1-0+deb12u3 cockpit-sosreport 287.1-0+deb12u3 cockpit-storaged 287.1-0+deb12u3 cockpit-system 287.1-0+deb12u3 cockpit-ws 287.1-0+deb12u3 dahdi 1:3.1.0-2 dahdi-dkms 1:3.4.0-6+asl dahdi-linux 1:3.4.0-6+asl
