Raspberry Pi 5, TYT 9000D, RIM-Alinco. I am at the point in terminal ASL3 menu where I am configuring the communication settings for the Pi and radio to communicate don’t match. I have tried different settings without luck, menu item 2 when chosen does not see the radio when PTT is pressed (no values being shown). Any suggestions, or help, thank you.
The setting from previous versions is as follows:
AllStar settings:
Simple USB
Carrier from = USB
CTCSS from = No
Tx Mix A = Voice Starting Values:
Tx Mix B = No Tx = 400
Deemphasis = Yes Rx = 460
P Filter = Yes
Rx Boost = 0
Tx Boost = 0
The menu in terminal as of now is:
- Select active USB device
- Set Rx Voice Level (using display)
- Set Transmit A Level (currently ‘400’)
- Set Transmit B Level (currently ‘400’)
B) Toggle RX Boost (currently ‘disabled’)
C) Toggle Pre-emphasis (currently ‘disabled’)
D) Toggle De-emphasis (currently ‘disabled’)
E) Toggle Echo Mode (currently ‘disabled’)
F) Flash (Toggle PTT and Tone output several times)
G) Toggle PL Filter (currently ‘enabled’)
H) Toggle PTT mode (currently ‘ground’)
I) Change Carrier From (currently ‘usb’)
J) Change CTCSS From (currently ‘no’)
K) Change RX On Delay (currently ‘0’)
L) Change TX Off Delay (currently ‘0’)
P) Print Current Parameter Values
S) Swap Current USB device with another USB device
T) Toggle Transmit Test Tone/Keying (currently ‘disabled’)
V) View COS, CTCSS and PTT Status
W) Write (Save) Current Parameter Values - Exit Menu
