Asl3 Shari vhf, no USB found
Asterisk Version: 22..x.y+asl3-3.n.m
ASL3 Version: 3.x.y
Inquiry
OS Kernel : 6.12.47+rpt-rpi-v8
Asterisk : 22.5.2+asl3-3.6.3-1.deb13
ASL [app_rpt] : 3.6.3
the quickest anallstar@AS-node67821:~ $ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0424:2514 Microchip Technology, Inc. (formerly SMSC) USB 2.0 Hub
Bus 001 Device 003: ID 0424:2514 Microchip Technology, Inc. (formerly SMSC) USB 2.0 Hub
Bus 001 Device 004: ID 046d:c534 Logitech, Inc. Nano Receiver
Bus 001 Device 006: ID 0424:7800 Microchip Technology, Inc. (formerly SMSC)
Bus 001 Device 092: ID 0d8c:0012 C-Media Electronics, Inc. USB Audio Device
this is the 1st time I have seen :
after running this command over 2 days of troubleshooting.
i immediately : asl-find-sound with no results as shown below
allstar@AS-node67821:~ $ asl-find-sound
in asl-menu “Node Settings….8) Interface Tune CLI
using option #2 set RX Voice Level……i am getting intermittent results.
Please enter your selection now: 2
Device 67821 is selected, the associated USB device string 1-1.1.2:1.0 was not found
Enter new value (0-999, or CR for none):
Rx voice setting not changed
Active Simple USB Radio device is [67821].
  1. Select active USB device
  2. Set Rx Voice Level using display (currently '650')
  3. Set Transmit A Level (currently '600')
  4. Set Transmit B Level (currently '500')
    B) Toggle RX Boost (currently 'disabled')
    C) Toggle Pre-emphasis (currently 'disabled')
    D) Toggle De-emphasis (currently 'disabled')
    E) Toggle Echo Mode (currently 'disabled')
    F) Flash (Toggle PTT and Tone output several times)
    G) Toggle PL Filter (currently 'disabled')
    H) Toggle PTT mode (currently 'ground')
    I) Change Carrier From (currently 'usbinvert')
    J) Change CTCSS From (currently 'no')
    K) Change RX On Delay (currently '0')
    L) Change TX Off Delay (currently '0')
    P) Print Current Parameter Values
    R) View Rx Audio Statistics
    S) Swap Current USB device with another USB device
    T) Toggle Transmit Test Tone/Keying (currently 'disabled')
    V) View COS, CTCSS and PTT Status
    W) Write (Save) Current Parameter Values
    X) View Tx Audio Statistics
  5. Exit Menu
never got this before either, during last 2 days of troubleshooting.
RX VOICE DISPLAY:
v -- 3KHz v -- 5KHz
the system seem to be unstable and i only get expected results very infrequently.
in Node Settings…..
  1. Radio Interface : SimpleUSB
  2. Duplex Type : 0 (i have also tried 1)
C) Customizations
i have it set to “ Kits4Hams SHARI PiHat, PiZero”
please advise what additional information i should be providing here, thank you.
If the rest of your configuration is good, you may need to add the line
usb_devices = 0d8c:0012       ; from lsusb
to your /etc/asterisk/res_usbradio.conf file, and restart asterisk.
That actually happened to me yesterday with a (previously working) UHF SHARI that had been offline in a drawer; I fired it up, changed the node # and it lost track of the audio device. It was easier to just re-image with the new Trixie release and transplant my previous audio settings than figure out how to manually fix it (which is my usual approach…I was just in a hurry in this case).
