ASL3 Second IAX calls drops first call - inbound call limit is one?
When a second caller dials in the first caller is disconnected. I have added tried adding maxcallnumbers = 20 to the iax.conf [hoip] stanza, no luck.
changed the above to max_connects = 0 this did not fix the call disconnect
Are they coming to the system logging into the same iax account ?
That would be a problem.
They are coming in via an HoIP extension, I resolved the problem with the configuration and it now accepts multiple simultaneous calls.
Steve
On Sat, Nov 7, 2026 at 4:33 PM KB8JNM-Mike <[email protected]> wrote:
Someone replied to your post.
| Mike
November 7 |
K4SGK:
I think you should share your fix to help others that may have had the same issue.
That is what the forum is for.
Then you could mark this as solved to kill the thread with that, elevating your 'solved' post.
Will do, currently traveling, will post the info in a week.
| Mike
November 8 |
K4SGK:
