ASL3 Port 80. How to change port Nr
Hi Team, I have searched the topics however, cannot find where to change current Port 80 to another number. I was hoping to use say 81 or similar for Allmon, Supermon or Allscan as Port 80 is used for another device and currently port forwarded in my Router.
This is easily done in Hamvoip….etc/httpd/conf/http.conf
Any help greatly appreciated.
Best 73 Mike
It’s easily done in Debian/ASL3 as well. The file is in /etc/apache2/ports.conf.
However you don’t need to change the port on the system to forward it in from your firewall. Just port forward in port 81 to your ASL3 system’s port 80. They don’t have to be the same number unless you have a very limited router/firewall device that can’t handle something that trivial.
you do not need to do that. Jut go into your router and under your port forward for port 80 to your node IP just change the external port to 81 then then local port remains at 80 to the node. this will allow it to become what ever port you want.
ex:
Supermon
81 <External port
80 <Internal Port
TCP
192.168.1.220
then your line to call it would be yournodenumber.nodes.allstarlink.org:81/supermon
Many thanks for the replies. Router port forwarding as per suggestions has the issue sorted. 73 Mike
I disagree,
My ISP blocks port 80. I edited ports.cont and changed it to 8089. Works greats. Plus, I have more then one web server running on my LAN network.
HTTP Services on my LAN network:
DVSwitch
Pi-Star
WPSD
OpenWebRX
Web Radio Control
NAS
Allmon3
it blocks port 80 INBOUND not on your local network side. so you ca run external 83 to internal 80 on that LAN address and it will go thru.
I have more than one node at the same location. In past on HamVOIP Icould assign port 81 to one node, port 82 to another and so on. Is there directions to do this for ASL3 out there?
Edit the above referenced file, restart apache2.
You can also do it in your router by specifying a different external port to port 80 internal to the IP address of that node.
