The status shows:
× logrotate.service - Rotate log files
Loaded: loaded (/usr/lib/systemd/system/logrotate.service; static)
Active: failed (Result: exit-code) since Thu 2026-09-03 07:11:12 EDT; 20min ago
Invocation: 34d98d271be7445a99bca620b9da5cd2
TriggeredBy: ● logrotate.timer
Docs: man:logrotate(8)
man:logrotate.conf(5)
Process: 9436 ExecStart=/usr/sbin/logrotate /etc/logrotate.conf (code=exited, status=1/FAILURE)
Main PID: 9436 (code=exited, status=1/FAILURE)
CPU: 180ms
Sep 03 07:11:12 node27274 logrotate[9436]: error: found error in file ppp, skipping
Sep 03 07:11:12 node27274 logrotate[9436]: warning: Potentially dangerous mode on wtmp: 0666
Sep 03 07:11:12 node27274 logrotate[9436]: error: Ignoring wtmp because it is writable by group or others.
Sep 03 07:11:12 node27274 logrotate[9436]: error: found error in file wtmp, skipping
Sep 03 07:11:12 node27274 logrotate[9436]: warning: Potentially dangerous mode on wtmpdb: 0666
Sep 03 07:11:12 node27274 logrotate[9436]: error: Ignoring wtmpdb because it is writable by group or others.
Sep 03 07:11:12 node27274 logrotate[9436]: error: found error in file wtmpdb, skipping
Sep 03 07:11:12 node27274 systemd[1]: logrotate.service: Main process exited, code=exited, status=1/FAILURE
Sep 03 07:11:12 node27274 systemd[1]: logrotate.service: Failed with result 'exit-code'.
Sep 03 07:11:12 node27274 systemd[1]: Failed to start logrotate.service - Rotate log files.
