ASL3 Image Needed
Where can I find and download the allstar3-arm64-3.0.19.img.xy image? Any help would be appreciated.
Please follow the instructions @ ASL3 Manual : ASL3 Appliance Installation
I’ve been told these instructions will install the Trixie OS and ASL3 which will not work with SkyWarn or SuperMon. That’s why I am looking for the older version of ASL3. I installed this newest version and can’t get either add-on to work.
If you need the latest "bookworm" image you should follow the same instructions. But, instead of specifying the https://rpi.allstarlink.org/latest.json URL you can use
https://repo.allstarlink.org/images/pi/latest-bookworm.rpi-imager-manifest
Thanks. I’ll give that a try.
The ASL3 appliance for Trixie includes Allmon3 for dashboarding. However if you want Supermon for some reason, that also works on Trixie I believe.
SkywarnPlus is no longer developed or maintained.
