I set up an ASL3 hub node on a Linode Debian 12 cloud computer. When the ASL3 cloud node transmits the CW ID, my Shari PiHat does not transmit the ASL3 hub node CW ID, so the CW ID is heard on my portable UHF transceiver. If I was using a UHF repeater station, the repeater’s CW ID would be heard on my UHF portable transceiver. I can hear the ASL3 hub CW ID on my RepeaterPhone and QSO One connection to my ASL3 hub node.
Is there a way to modify the /etc/asterisk.rpt.conf file so that when the ASL3 hub node CW ID occurs, the Shari PiHat would then retransmit the CW ID to my UHF portable transceiver? Then it would behave the same way as a repeater being received on my UHF portable transceiver. I also do not want to hear any courtesy beeping. Preferably only the CW ID and possibly the node connect and disconnect announcements.
No. It's up to each local transmitter to ID itself. If you allow the hub to transmit the ID over IAX, then any station connected to it would hear that ID, which is a great way to get you disconnected from nodes outside of your control for being a nuisance.
The reason you can hear the ID on WT connections is that context is sent the audio as if you are listening to the output of app_rpt.
I personally have all my hub nodes not ID, because it's pointless, since they are not attached to RF directly.
