ASL3 does not allow more than one phone calls in a specific phone node
If you make a second phone call whilst the first phone call is already in process it kicks the first phone call. here is my config
extensions.conf
[1010]
exten => 441452831580,1,Goto(1010,s,1)
exten => s,1,Ringing
exten => s,n,Answer(3000)
exten => s,n,Set(CHANNEL(audioreadformat)=ulaw)
exten => s,n,Set(CHANNEL(audiowriteformat)=ulaw)
exten => s,n,Playback(rpt/connected-to)
exten => s,n,Playback(rpt/node)
exten => s,n,SayDigits(1010)
exten => s,n,rpt(1010|Pv)
exten => s,n,Hangup
pjsip.conf
[1010]
type=registration
server_uri=sip:X
client_uri=sip:X
outbound_auth=1010-auth
contact_user=441452831580
[1010-auth]
type=auth
auth_type=userpass
username=X
password=X
[1010]
type=aor
contact=sip:X
[1010]
type=endpoint
transport=transport-udp
context=1010
allow=alaw
allow=gsm
allow=ulaw
aors=1010
[1010]
type=identify
endpoint=1010
match_request_uri=sip:X
not even AI can solve this one...
and to be clear the provider allows 5 simultaneous callers
Without more context, it's guessing. But it looks like you're trying to use the same identifier over and over which app_rpt won't allow. Each connected number/name needs to be unique.
I have used 2 different phone numbers. When I call the number with a second number, it kicks off the first call despite them being two different numbers.
On Sat, 17 Oct 2026 at 17:32, N8EI <[email protected]> wrote:
Someone replied to your post.
| N8EI ASL Community Admin
October 17 |
Make sure you're setting the CALLERID(name) and CALLERID(num).
