ASL3 + DigiRig Mobile
Asterisk Version: 22..x.y+asl3-3.n.m
ASL3 Version: 3.x.y
Allstar node issue
Setup
  • Raspberry Pi 4 running ASL3
  • Node: 68967
  • Radio: Yaesu FT-2900R
  • Interface: DigiRig Mobile
  • Connection:
    • RX audio: rear speaker jack → DigiRig
    • TX audio: DigiRig → front mic jack
    • USB: Pi ↔ DigiRig
What works
  • Node starts and exists
  • Can connect to nodes (e.g., 2000)
  • USB audio device detected (aplay -l)
  • RX audio confirmed (RxAudioStats changes)
  • Serial port present: /dev/ttyUSB0
  • PTT confirmed working via Python using DTR (keys radio reliably)
What does NOT work
  • No COS change in SimpleUSB (carrierfrom=usb or usbinvert)
  • No TX using SimpleUSB (Flash does not key radio)
  • Attempting to hook external PTT scripts into rpt.conf caused Asterisk to exit
Key observation
  • DigiRig presents:
    • audio via USB :check_mark:
    • serial control via /dev/ttyUSB0 :check_mark:
  • It does not expose CM108 GPIO (no usable COR/PTT via hidraw)
Problem
  • app_rpt / SimpleUSB expects GPIO-based PTT/COR
  • DigiRig provides serial PTT (DTR/RTS)
:backhand_index_pointing_right: These control methods do not align
Question
What is the supported method in ASL3 to:
  • Use USB audio for RX/TX
  • Use /dev/ttyUSB0 (DTR) for PTT
  • Use audio-based RX detection (since no COR line)
WITHOUT modifying hardware?
Goal
Use DigiRig Mobile with ASL3 + FT-2900:
  • no VOX
  • no hardware mods
  • no GPIO wiring
If the Digirig doesn’t expose the GPIO pins from the CM108/119 then you’re not going to be able to signal the radio directly without modification. ASL does not support PTT via serial.
DigiRig does expose the needed GPIO pins internally. the designer was sure it would be handy! :grin:
the GPIO pins are routed to thru-holes on the pc board and i have seen a post that one wire jumper is all that is needed to get all the hardware signalling set up
have a look https://www.youtube.com/watch?v=RYtGDxKNouc
let us know how it goes ..
He said he wanted not to modify it. A DigiRig was built for digital modes where the radio is controlled over a CAT connection. Repeaters and ASL work fundamentally differently.
the described modification is purported to allow the DigiRig to be used both for digital modes and ASL. as best i could tell (schematic), the jumper allows "normal" (serial port) signal change and audio chip signal change. it's a parallel circuit hookup, so no application conflict.
there will be no CAT offered in ASL service with this configuration - use SimpleUSB interface method.
also: a removable jumper isn't exactly a "hardware mod" in my book. although it will be necessary
I understand all that. My point was the OP didn't want to modify the adapter.
Well, i did not want to modify the digirig, but I guess I am going to take another look at that option.
I'm in a similar boat. Using a Yaesu FT-1900R with Digirig Mobile on Debian 12 (laptop). Tried everything I could find to get ASL3 to PTT the radio to no avail. The Digirig is version 1.11, a bit different than the one used with the mod - 1.9. I asked on the Digirig forum and K0TX said it shouldn't need any modification. Running minicom keys up the radio as soon as it opens so I assume the wiring should all be good.
I've tried so many configurations between SimpleUSB and USBRadio I've lost track of all the attempts. At one point, at least one configuration recognized audio coming in but the node didn't respond but none of them would key up. Any ideas would be appreciated.
when you say "mod" do you mean the one wire jumper from a GPIO audio chip pin to PTT?
Yes, that's the one.
Still can't get ASL3 working with Digirig Mobile and FT-1900. I've tried every combo with no luck. The radio keys up fine testing it with WSJT-X. Do I need a different interface to use this radio with AllStarLink?? I'm stuck using an ~8w Baofeng until I can figure out the issue.
Minicom and WSJT-X commands a serial chip IO pin to effect PTT
the ASL SimpleUSB interface commands a CM108 audio chip IO pin to effect PTT
There are many vendors that offer "Ready to go" adapters. DigiRig is not among them. Master Communications, AllScan, DMK Engineering, just to name a few.
