I am running ASL3 on a Dell WYSE 3040 and I have several cop functions un-commented. They function as intended except cop,1 system warm boot does not work.
Fred
KI6EAY
Fred
KI6EAY
On one of my test nodes I uncommented (removed the leading semi-colon from) this line :
;901 = cop,1
Then, I restarted asterisk with :
sudo astres.sh
Then, to test the function I exec’d :
sudo asterisk -x 'rpt fun 1999 *901'
and “asterisk” was restarted.
What behavior were you expecting?
From a portable with a keypad I send *901. ASL3 does not warm boot. All other cop commands I have uncommented work as intended.
KI6EAY
As above, I uncommented the /etc/asterisk/rpt.conf line with “;901 = cop,1” to be “901 = cop,1” (removing the semi-colon). I then restarted asterisk so that it would pickup the configuration file change. But, this time, instead of using the CLI to issue the DTMF sequence I used my HT (*901). Again, “asterisk” restarted.
What “warm boot” behavior were you expecting?
