I know there have been multiple ASL3 autopatch threads already, but I feel like my situation is different enough to warrant a separate thread. It seems like the issues in the other threads were reported as fixed recently, so I’m unsure if I’m running into bugs or just failing to get the configuration correct.
I am attempting to implement autopatch (and hopefully reverse autopatch too) on my single-node ASL3 system. My single node is a VOTER system. I can find several guides and examples online for autopatch setup, all of which seem to differ slightly:
These are the Asterisk configuration examples provided by VoIP.ms:
I have been through all of these and can’t get an outgoing call established. The farthest I have been able to get is this, using IAX2:
[2024-08-22 11:20:13.030] WARNING[25684]: app_rpt/rpt_bridging.c:572 rpt_play_tone: Cannot start tone on DAHDI/pseudo-1855143395
[2024-08-22 11:20:15.445] WARNING[25685][C-00000009]: bridge.c:776 bridge_base_init: Bridge 19cd1d38-b099-4684-9397-babcc4a22322: Could not create class basic. No technology to support it.
[2024-08-22 11:20:15.467] WARNING[25684]: app_rpt/rpt_bridging.c:572 rpt_play_tone: Cannot start tone on DAHDI/pseudo-1855143395
Or this, using SIP:
[2024-08-22 08:06:08.510] WARNING[19549] app_rpt/rpt_bridging.c: Cannot start tone on DAHDI/pseudo-1337296973
[2024-08-22 08:06:08.510] ERROR[19550][C-00000009] rtp_engine.c: No RTP engine was found. Do you have one loaded?
[2024-08-22 08:06:08.510] NOTICE[19550][C-00000009] app_dial.c: Unable to create channel of type 'SIP' (cause 20 - Subscriber absent)
[2024-08-22 08:06:08.520] WARNING[19549] app_rpt.c: has no PBX?
[2024-08-22 08:06:08.540] WARNING[19549] app_rpt/rpt_bridging.c: Cannot start tone on DAHDI/pseudo-1337296973
Here are my configurations (with some non-related info removed for a cleaner thread)…
rpt.conf:
[general]
node_lookup_method = both
[nodes]
55199 = radio@127.0.0.1/55199,NONE
[node-main](!)
rxchannel = dahdi/pseudo
duplex = 2
context = radio
callerid = "Repeater" <VOIPMS_DID_NUMBER>
accountcode = RADIO
[55199](node-main)
rxchannel = Voter/55199
duplex = 2
context = voipms
[functions]
6=autopatchup,context=voipms,noct=1,farenddisconnect=1,dialtime=20000,quiet=1
0=autopatchdn
iax.conf:
[general]
register => VOIPMS_USERID:VOIPMS_PASSWORD@dallas1.voip.ms
bindport = 4569
disallow = all
allow = ulaw
allow = adpcm
allow = gsm
jitterbuffer = yes
forcejitterbuffer = yes
dropcount = 2
maxjitterbuffer = 4000
maxjitterinterps = 10
resyncthreshold = 1000
maxexcessbuffer = 80
minexcessbuffer = 10
jittershrinkrate = 1
tos = 0x1E
autokill = yes
delayreject = yes
[voipms]
type = peer
username = VOIPMS_USERID
secret = VOIPMS_PASSWORD
host = dallas1.voip.ms
context = voipms
disallow = all
allow = ulaw
requirecalltoken = yes
insecure = port,invite
[radio]
type = user
disallow = all
allow = ulaw
allow = adpcm
allow = gsm
codecpriority = host
context = radio-secure
transfer = no
#tryinclude custom/iax.conf
sip.conf:
[general]
context=default
allowoverlap=no
bindport=5060
bindaddr=0.0.0.0
srvlookup=yes
register => VOIPMS_USERID:VOIPMS_PASSWORD@dallas1.voip.ms:5060
[voipms]
type=peer
context=voipms
host=dallas1.voip.ms
username=VOIPMS_USERID
secret=VOIPMS_PASSWORD
disallow=all
allow=ulaw
nat=yes
canreinvite=no
insecure=invite
extensions.conf:
[general]
static = yes
writeprotect = yes
[globals]
HOMENPA = 501
NODE = 55199
[default]
exten => i,1,Hangup
[voipms]
include => voipms-outbound
[voipms-outbound]
exten => _1NXXNXXXXXX,1,Dial(IAX2/voipms/${EXTEN})
exten => _1NXXNXXXXXX,n,Hangup()
exten => _NXXNXXXXXX,1,Dial(IAX2/voipms/1${EXTEN})
exten => _NXXNXXXXXX,n,Hangup()
exten => _011.,1,Dial(IAX2/voipms/${EXTEN})
exten => _011.,n,Hangup()
exten => _00.,1,Dial(IAX2/voipms/${EXTEN})
exten => _00.,n,Hangup()
[radio-secure]
exten => _XXXX!,1,NoOp(Connect from node: ${CALLERID(num)})
same => n,NoOp(Connect to: ${EXTEN})
same => n,NoOp(The Channel IP is ${CHANNEL(peerip)})
same => n,GotoIf($["${CHANNEL(peerip)}" = "127.0.0.1"]?connect)
same => n,GotoIf($[${DB_KEYCOUNT(allowlist/${EXTEN})} = 0]?denylist)
same => n,GotoIf(${DB_EXISTS(allowlist/${EXTEN}/${CALLERID(num)})}?connect)
same => n,NoOp(${EXTEN} not in allowlist, Hangup)
same => n,Hangup
same => n(denylist),GotoIf(${DB_EXISTS(denylist/${EXTEN}/${CALLERID(num)})}?:connect)
same => n,NoOp(${EXTEN} is in denylist, Hangup)
same => n,Hangup
same => n(connect),rpt(${EXTEN})
same => n,Hangup
[pstn-out]
exten => _NXXNXXXXXX,1,playback(ss-noservice)
same => n,Congestion
[radio]
exten => _X11,1,Goto(check_route,${EXTEN},1)
exten => _NXXXXXX,1,Goto(check_route,1${HOMENPA}${EXTEN},1)
exten => _1XXXXXXXXXX,1,Goto(check_route,${EXTEN},1)
exten => _07XX,1,Goto(parkedcalls,${EXTEN:1},1)
exten => 00,1,Goto(my-ip,s,1)
[check_route]
exten => _X.,1,Noop(${EXTEN})
exten => _1800NXXXXXX,2,Goto(invalidnum,s,1)
exten => _1888NXXXXXX,2,Goto(invalidnum,s,1)
exten => _1877NXXXXXX,2,Goto(invalidnum,s,1)
exten => _1866NXXXXXX,2,Goto(invalidnum,s,1)
exten => _1855NXXXXXX,2,Goto(invalidnum,s,1)
exten => _1X00XXXXXXX,2,Goto(invalidnum,s,1)
exten => _1X11XXXXXXX,2,Goto(invalidnum,s,1)
exten => _X11,2,Goto(invalidnum,s,1)
exten => _1NXX555XXXX,2,Goto(invalidnum,s,1)
exten => _1NXX976XXXX,2,Goto(invalidnum,s,1)
exten => _1809XXXXXXX,2,Goto(invalidnum,s,1)
exten => _1900XXXXXXX,2,Goto(invalidnum,s,1)
exten => _1NXXXXXXXXX,2,Goto(pstn-out,${EXTEN:1},1)
exten => _X.,2,Goto(invalidnum,s,1)
#tryinclude custom/extensions.conf
