I keep getting terminal size must be at least 22 lines when trying to access cli menu. I am typing sudo asl-menu in terminal. thanks vk4yeo
The menus were designed to work in a Terminal window with a minimum size. The menu expects the window size to be at least 20 rows and 60 columns. If your window is too small, make it bigger.
Thanks. Being an absolute computer dummy. Can you explain how to increase the size please. Thanks vk4yeo
The specifics would depend on whether you are using a web browser based Terminal window (e.g. the Cockpit Web Admin Portal, "Terminal"), an application on your desktop/laptop, or some other way. If you are accessing the terminal using a web browser then make the browser window taller, just as you would change the size of the window when viewing any other content. If you are using an application, nearly all will also let you change the size of the window. If you make the windows taller you should end up with more lines.
While I can't speak to all of them, most terminals will allow you to set size and other parameters on a per session/connection.
So, you might have to check the settings for the exact connection.
But there should be general default settings as well. But connections already made may be stuck with what has already been set-up and saved using old defaults.
Just keep that in the back of your mind if you change the general defaults and it does not yield anything for you.
Load the connection data then change the settings before connection. If that is possible.
If you are still stuck, tell us exactly what you are using.
Usually reducing the font size fixes this issue. As everyone else mentioned, knowing what program you are using would be a help
