ASL3 and Broadcastify stream (ezstream) stopping
My stream works for hours but seems to randomly stop, I created a watchdog and checks every 30 and if the stream is down will do a restart. Not optimal when I need to solve the root cause. Nothing in the logs. This device worked when on broadband internet just fine, I think the issue started when moved to a hotspot at the repeater site and the hotspot may be the issue but the ASL / Echolink is always connected and that does not disconnect.
Anyone had similar or know any settings may be more suited for hotspot or disconnect issues?
OS Kernel : 6.12.47+rpt-rpi-v8
Asterisk : 22.5.2+asl3-3.6.3-1.deb12
ASL [app_rpt] : 3.6.3
Installed ASL packages :
Package Version
allmon3 1.7.0-1.deb12
asl3 3.11-1.deb12
asl3-asterisk 2:22.5.2+asl3-3.6.3-1.deb12
asl3-asterisk-config 2:22.5.2+asl3-3.6.3-1.deb12
asl3-asterisk-modules 2:22.5.2+asl3-3.6.3-1.deb12
asl3-menu 1.15-1.deb12
asl3-pi-appliance 1.10.1-1.deb12
asl3-tts 1.0.1-1.deb12
asl3-update-nodelist 2.0.0-1.deb12
EZStream Settings /etc/ezstream.xml
<ezstream>
<verbosity>1</verbosity>
    <logfile>/var/tmp/ezstream.log</logfile>
    <servers>
        <server>
            <protocol>HTTP</protocol>
            <hostname>audio9.broadcastify.com</hostname>
            <port>80</port>
            <password>HIDDEN</password>
            <tls>none</tls>
        </server>
    </servers>
    <streams>
        <stream>
            <mountpoint>/HIDDEN</mountpoint>
            <format>MP3</format>
                <stream_name>Repeater</stream_name>
                <stream_url>https://www.broadcastify.com/listen/feed/HIDDEN</stream_url>
                <stream_genre>Amateur Radio</stream_genre>
                <stream_description>Repeater</stream_description>
                <stream_bitrate>16</stream_bitrate>
                <stream_channels>1</stream_channels>
                <stream_samplerate>22050</stream_samplerate>
                <stream_public>Yes</stream_public>
<reconnect_tries>0</reconnect_tries>   <!-- 0 = infinite -->
<reconnect_delay>10</reconnect_delay>
        </stream>
    </streams>
    <intakes>
        <intake>
            <type>stdin</type>
        </intake>
    </intakes>
</ezstream>
In my /etc/asterisk/rpt.conf this is my configuration
outstreamcmd = /bin/sh,-c,"/usr/bin/lame --preset cbr 16 -r -m m -s 8 --bitwidth 16 - - "
Check out this other thread I started on it.
