Previous repo version on rpi would report status to the asl cloud. after an upgrade to 2:20.10.0 neither of the 2 nodes where this update was performed now report status. Reboots didn’t help. Using asl-menu I checked that the config setting “post status” was set to post.
On my node 620592 I can login to the allmon3 dashboard. It reports at the top the 620592 node. When I try to initiate a link using allmon3 to another of my nodes it reports in the command response area at the bottom: “OK Unknown node number 620592” which is strange.
If rpt stats reports nothing then there is definitely something broken with your configuration. Did you try to merge old and new configs during the update?
the “update” was automatic in the sense that the rpi system software update listed asterisk/asl3 update and I checked it to be done. Then it all proceeds automatically with no user interaction. In the past when these updates happened the installer “did the right thing” and didnt mess with the configuration settings. So I dont know what it did.
Been a long time without working… we updated to asl3 3.7.1-1.deb with asterisk 20.11.0+asl3-3.2.0-2.deb12 with apt-rpt 3.2.8. No change.
rpt show registrations reports rpt command not found.
