ASL Web UI - not loading
I'm running a pi4 w ASL3 and latest updates. The cockpit does not say what version of Linux is running but instructions says existing appliance users only need be updated. The instruction for address is confusing- the examples don't match up: " ...open https://<your-node>/ - for example https://node63001.local/"
I'm not sure which part you're confused about. If you named your system "node63001" when you imaged it, then it should be on your network as https://node63001.local/. When you browse to it, you should get the appliance landing page.
I just got the email link a few days ago .. I must say, initial installation instructions are quite incomplete .. the nginx settings are ambiguous at best .. and accessing the web UI will not show up as https as it says it would …
Hi- The first example suggests " https://<your-node>" instead of " https://<your-node>.local/ It does not matter- I get it based on the 2nd example- just threw me bc they don't match.
My node hostname from cockpit is ASL48654 and when entered does not load a web page
https://ASL48654.local/
I can get to the cockpit using the ip and port 9090. Not sure what the issue is. I turned off my VPN just to test and then https://ASL48654.local/ just loads the cockpit page. Odd bc I use cockpit, Allscan, Herald via ip with VPN on. I guess it interferes w hostname addresses for some reason and not ip based addresses. The Pi and PC are on the same LAN, nothing unique there.
Thx
You should be able to simply include /etc/asl-web-ui/nginx.conf; in the relevant server { } blocks and it "just works". At least that's been my testing experience. I'd like to know what didn't work.
That's a little confusing but only because everyone's network will behave differently. The .local assumes you're running the appliance which means the mDNS is sending the name out on your LAN every so often. Your system has to notice it and start using it. Also, using any sort of VPN will break mDNS. The alternative is to go to a known hostname and/or IP address as documented.
Looked at github page then the manual- the address is listed as "https:///asl-web-ui/" at Installing and Logging In - AllStarLink Manual
The orig post here left out the /asl-web-ui/ portion of the address.
When I use that address via ip I get an Apache message saying:
"Not Found
The requested URL was not found on this server.
Apache/2.4.71 (Debian) Server at 192.168.1.188 Port 443"
Is there a way to locate and verify the web ui is installed properly? I looked in var/www but nothing there and I have no idea where else to look. Thx.
Just exactly how do you include the “yada yada” in the brackets .. and what where are these brackets? Why wasn’t this included in the install script?
.. we need to see the line by line command line sequence, straight up (aka “see John run”) style.
BTW I’m a coder, but not at all an html’er
Is this an ASL3 Appliance or just running ASL3 on a Debian install? What's the output of dpkg -l | grep asl?
The assumption is that people who have manually switched over to Nginx know what they're doing. All of the appliance-systems and default behavior is centered around Apache. Apache is very novice-friendly with configuration. Nginx is more complex. That's why the default system is Apache for ASL systems.
