ASL Web Portal SSL certificate
Hello Everyone,
I know this has been asked before (link below), but I need a little more info…. I’m using certbot it has generated multiple certificates. I’ve tried to copy these directly into /etc/cockpit/ws-certs.d and deleting the self signed certificates. I’ve tried to rename the .pem files to .key and .cert to match the self signed keys, but no luck.
I have these files in the live directory of letsencript: cert.pem, chain.pem, fullchain.pem, privkey.pem
Which ones do I need and what should the file name be once copied?
FYI. The keys work for for supermon, allmon3, DVSwitch & the ASL main cockpit page.
Will
WY7WL
All you need to do is create symlinks to the "live" links:
root@node48496:/etc/cockpit/ws-certs.d# pwd
root@node48496:/etc/cockpit/ws-certs.d# ls -l
total 0
lrwxrwxrwx 1 root root 56 Jan  3  2025 50-node48496.cert -> ../../letsencrypt/live/node48496.w8wky.org/fullchain.pem
lrwxrwxrwx 1 root root 54 Jan  3  2025 50-node48496.key -> ../../letsencrypt/live/node48496.w8wky.org/privkey.pem
And delete the rest.
Ok, I wasn’t using the fullchain.pem
However, its still making self signed keys… All browsers closed, rebooted the server, and using incognito browser.
total 8
-rw-r--r-- 1 root root 1314 Jan  5 02:26 0-self-signed.cert
-rw------- 1 root root 1704 Jan  5 02:26 0-self-signed.key
lrwxrwxrwx 1 root root   52 Jan  5 02:21 fullchain.pem -> /etc/letsencrypt/live/ke8vny.wy7wl.com/fullchain.pem
lrwxrwxrwx 1 root root   50 Jan  5 02:21 privkey.pem -> /etc/letsencrypt/live/ke8vny.wy7wl.com/privkey.pem
Got it.
The file name needs to reflect the domain.key or domian.cert.
Missed that.
