Looks right. Do you get any response from that when you run it on the CLI? Also open another ssh session and watch the asterisk CLI when running the command from the first session.
== Parsing ‘/etc/asterisk/asterisk.conf’: Found
Connected to Asterisk GIT Version 004b9dd currently running on ip-172-31-27-215 (pid = 2828)
Verbosity is at least 11
ip-172-31-27-215*CLI> rpt fun 523800 11997
ip-172-31-27-215CLI>
ip-172-31-27-215*CLI> rpt fun 523800 11997 ip-172-31-27-215CLI>
How would I go about that? This server is Ubuntu 16.0.4 and I manually installed with these commands from the wiki: cd /tmp
wget http://dvswitch.org/install-allstarlink-repository
chmod +x install-allstarlink-repository
./install-allstarlink-repository
First thing: *cli> core set verbose 3 so you can see what the heck is going on when you test your commands.
Are you saying that *cli> rpt fun 523800 *11997 doesn’t work… no response… no nothing? If so you have a very basic problem. Are you connected in the first place (that’s a disconnect command, you know)? Do nodes 523800 and 1997 actually exist on your server? Because if they don’t exist or your not connected (and using a disconnect command) a nothing response is normal.
