Interesting idea of the graph.
Would make it easier for all. And would make a good inclusion to the wiki if you are willing.
There is a setting that affects the COR line that should be marked I guess.
rxondelay=x each number is 20ms
It is the time delay that a valid COR happens before it is registered in the software as a valid cor.
Being as such, would automatically delay the ptt as well for it looks at valid cor past the rxondelay.
(commonly used to eliminate interference like kerchunking/pops)
I’ll have to take a deeper look when I have time as I’m sure there are some more things that could be added to that graph.
Sorry, I’m not good with data on sound fobs. Someone will chime in.
