ASL setup (N8AR v4.2)
Having an issue. Literally following the Supermon and Allmon setup provided in the Shari ASL3 document for my new node. Using 3.0.19 image. All steps outlined to install Supermon seem to work. But, when opening up the file location to edit the “allmon.ini” it gives me a blank form. This file is not apparently being created containing the default info that I am supposed to edit. It shows up when opened as “New File”………so could use some help as the next step in the Setup Outline guide is for Allmon. Anyone know where the fault lies? Is there a new version of the setup? Thanks.
Just to add, I could not find this file in /var/www/html/supermon
or in my root by going back to cd\
Is it hiding somewhere else? No directory info or changes are called out in the guide.
Are you asking a question about Allmon3 or Supermon? For Allmon3., all configuration is in /etc/allmon3. Supermon isn't an ASL3 application or supported by the ASL Project - they have a Groups.io that would be a better place to get help.
Thank you for that info. I will go back to the Shari group for support.
