Asl-say global ip4 address
I am using the asl-say ip4 command to get my local eth and wifi addresses to be said over radio. What do i use to get the public ip4 address?
I intended to say public ip4 address
There’s an example on how to do just that using asl-tts shown at ASL Text-to-Speech - AllStarLink Manual
I do it like this in the dialplan. (this is from a sub-menu)
How you reach the dialplan from a command is up to you.
[my-ip]
exten=s,1,Set(MYADDR=${CURL(https://api.ipify.org?format=json)})
exten=s,2,Wait,3
exten=s,3,SayAlpha(${MYADDR})
exten=s,4,Hangup
You can run this in your browser to see the data returned and will be played by allison carried by the var MYADDR.
Perhaps that is enough to get you to what you are building.
How to add DTMF commands on ASL3 to say your node’s LAN and WAN IP addresses, and turn WiFi on & off. (From this FB Post)
For nodes that have built-in WiFi but that do not have a screen, keyboard, Desktop GUI, etc. it can be useful to turn wifi on and off with a DTMF command. WiFi will generally be enabled by default when the node powers on, but when connecting an ethernet cable it is best to first disable WiFi so there are not then 2 IP addresses assigned which can greatly slow down networking. Or networking can be set up (as described in the AllScan How-To Guides) to have WiFi Off by default if you generally use wired ethernet, and in that case the below commands can be used to turn on WiFi when needed.
  1. Add below under [functions] section in rpt.conf if not already there:
    69 = autopatchup,context=my-ip,noct=1,farenddisconnect=1,dialtime=9000,quiet=1
  2. Update below section in extensions.conf:
    [my-ip]
    ; *690: Say LAN IP Address
    exten => 0,1,AGI(getip.sh)
    exten => 0,n,Wait(1)
    exten => 0,n,SayAlpha(${result})
    exten => 0,n,Hangup
    ; *691: Say WAN IP Address
    exten => 1,1,Set(result=${CURL(https://api.ipify.org)})
    exten => 1,n,Wait(1)
    exten => 1,n,SayAlpha(${result})
    exten => 1,n,Hangup
    ; *692: Turn Off Wi-Fi
    exten => 2,1,AGI(wifidown.sh)
    exten => 2,n,Wait(1)
    exten => 2,n,Playback(/usr/share/asterisk/agi-bin/wifidisabled)
    exten => 2,n,Hangup
    ; *693: Turn On Wi-Fi
    exten => 3,1,AGI(wifiup.sh)
    exten => 3,n,Wait(1)
    exten => 3,n,Playback(/usr/share/asterisk/agi-bin/wifienabled)
    exten => 3,n,Hangup
  3. Create file /usr/share/asterisk/agi-bin/getip.sh with below lines and chmod file to 775:
    #!/bin/bash
    echo SET VARIABLE result *hostname -I*
    *Note: Use backticks around hostname -I (this forum won’t show them in inline text)
  4. Create file /usr/share/asterisk/agi-bin/wifidown.sh with below lines and chmod file to 775:
    #!/bin/bash
    ifconfig mlan0 down
    Note: “mlan0” is the name of the WiFi interface on Dell 3040’s. If you have some other MiniPC/RPi the name is probably different. See the How-To Guides at https://allscan.info/ for further details on how to set up WiFi.
  5. Create file /usr/share/asterisk/agi-bin/wifiup.sh with below lines and chmod file to 775:
    #!/bin/bash
    ifconfig mlan0 up
  6. Update modules.conf following lines:
    load => res_agi.so
    load => res_speech.so
  7. Install asl-tts by running the following commands:
    sudo apt install asl3-tts
    Test that it’s working by running the following:
    sudo asl-tts -n [YOUR NODE#] -t 'AllStar is the hottest thing since sliced bread'
  8. Create the wifi enabled/disabled audio files:
    sudo asl-tts -n [YOUR NODE#] -t "WiFi enabled" -f /usr/share/asterisk/agi-bin/wifienabled
    sudo asl-tts -n [YOUR NODE#] -t "WiFi disabled" -f /usr/share/asterisk/agi-bin/wifidisabled
Now restart Asterisk or reboot the node. The following commands can now be executed:
*693: Turn On Wi-Fi
These commands only affect the current power on session. WiFi will return to its default on or off state after a power cycle or reboot.
This method using SayAlpha to announce the IP address seems to result in the audio being played to connected nodes. Might there be another command that will only play the audio on the local node?
David, WD5M
I only use these commands when not connected to any other nodes so that has not been an issue for me, but it would be nice to know what alternatives there might be to the SayAlpha / Playback Asterisk Dialplan functions that would play audio locally only. ASL TTS is probably the best option, and I do use that in my current DTMF commands (which have been updated since this original thread) - see AllScan/docs/extensions.conf at main · davidgsd/AllScan · GitHub and AllScan/_tools/agi-bin/sayip.sh at main · davidgsd/AllScan · GitHub for examples.
My quick and dirty solution was to (1) replace the *690 extensions.conf 1st 3 command lines before Hangup that use SayAlpha with:
exten => 0,1,AGI(sayip.sh,${NODE})
And (2) copy the sayip.sh script to saywanip.sh and modify it to just say the WAN IP address. Then replace the *691 extensions.conf 1st 3 lines before Hangup with:
exten => 1,1,AGI(saywanip.sh,${NODE})
It still kerchunks the link when the DTMF codes are sent, but the responses is no longer played over the link.
I suppose it won’t take too many forced disconnects from hubs and possible denylist additions for users to learn not to run these commands during an active connection.
David, WD5M
