ASL Proxy broken in ASL3?
Asterisk Version: 2:22.4.1+asl3-3.5.4-1.deb12
ASL3 Version: 3.8-1.deb
I am trying to use the ASL proxy feature for mobile Shari node, it was working on older config. Using the wiki at Proxy - AllStarLink Wiki.
When trying to connect to node from shari I get this message on the proxy:
[Jul 19 11:14:44] NOTICE[2134]: chan_iax2.c:9471 socket_process: Rejected connect attempt from 108.21.160.123, request '0%s@radio-in' does not exist
So I'm guessing something in the app_rpt code has changed to not allow the varriable 0%s in rpt.conf [nodes] stanza.
Scott
You'll want to be using the new manual at https://allstarlink.github.io/. Look for SA818 under Advanced Topics.
I don't know how much of the Wiki doc is still relevant in ASL3.
It should work, but that page hasn't yet been updated for Asterisk 22 configuration. There are some differences. You'd likely need to compare other stanzas in extensions.conf to see what's changed.
I have incoming working to the shari via the proxy. :grinning_face:
I can make an outgoing connection to my node if I put
2298 = radio-proxy-out/02298,NONE
In the nodes stanza in rpt.conf
So as best I can tell %s = outgoing node number and maybe ,NONE so what is the equivalent in current asterisk? Is %s the from the variable in the source code?
Any Thoughts?
Scott
I don’t have anything intelligible to add here other than I would also like to have a working Proxy again. My old VPS died and I need to rebuild it. Can someone help get the proxy wiki page updated?
I’m not sure if this is useful to anyone, but being new to ASL, it wasn’t obvious to me…. You don’t NEED a transparent proxy setup if you’re willing to deal with two nodes.
  1. Set up one hub node in the cloud on a VPS that is publicly accessible.
  2. Connect FROM your local behind-the-firewall node to your public VPS node.
  3. Then manage all your lovely connections from the public node’s Allmon UI.
Just be sure to set up a firewall on the public node so you don’t get pwnd.
Again, obvious to most I’m sure. But for us noobs, this might be helpful. <3
I’m not sure if this was just my setup, but the public node wouldn’t authenticate my private node, so I added it to the [nodes] section. Public node is 500001. Private node is 500000.
LOCAL PRIVATE NODE:
; rpt.conf
[500000](node-main)
startup_macro = *3500001 ; connect to node 500001 at startup
PUBLIC VPS NODE:
; rpt.conf
[nodes]
500000 = radio@127.0.0.1/500000,NONE ; ip address doesn't matter I guess
500001 = radio@127.0.0.1/500001,NONE
I wasn’t sure why I needed to manually add a node entry in rpt.conf, and it’s interesting that it didn’t even have to be the correct IP for my home node. But without that entry the connection was denied.
I'm assuming you're using "500000" and "500001" as examples here. But for anyone else who sees this thread, make sure that any private node uses a number between 1000 and 1999.
Yes, those are placeholders, but I did use two real node numbers. It works fine. Is there a reason why my private at-home node cannot use a real node number? Or can you point to some docs so I can understand better?
Thanks!
Yes, it will work fine but they aren't "private nodes". That concept is reserved for numbers 1000-1999. Using node numbers assigned to you above 2000 is fine in the way you describe but they're still routable node numbers in theory. You can render them unreachable in a variety of methods including non-registration (orphans data) or firewall rules.
Ahh, very sorry there. I hate to use wrong terminology. And thank you for educating me!
The forum won’t let me edit the post because it’s too old. Just mentally replace “private” with “at-home” in my post – that’s what I meant. :slight_smile:
