Does ASL support the RPi 3 WiFi? If so, what do I need to know to set it up. I didn’t find any info on the wiki.
Bob
K6ECM
Sent from iPad
Bob
K6ECM
Sent from iPad
Bob, this is not a matter of ASL supporting it but rather a matter of the underlying operating system. I can’t speak to the .img that is pre-built but I will say that if you use a vanilla version of Raspbian and go from there (following the directions of how to setup the supplicant and all the requisite things) then it should work… https://www.raspberrypi.org/documentation/configuration/wireless/wireless-cli.md
Of course not using the supplied image also may come with it’s own challenges too…
JJC
N0PKT
Bob
K6ECM
Sent from iPad
ASL supports whatever IP address you obtain, however you obtain it.
WIFI is not part of ASL but the operating system.
Try looking for wifi on a debian 9 Pi.
I ran the OS menu once, but I don't remember what it was and the wifi setup is in there. But you can find it on the web.
...mike/kb8jnm
Bob
K6ECMSent from iPad
http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-usersTo unsubscribe from this list please visit http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button"
From the command line of ASL 1.01 ( repeater@repeater:/ $ ) type sudo wifi-setup the script will create the required files for the system for use. You may also manually edit the file to add additional wifi networks.
Cool, and it works! One question. What is the protocol for multiple WiFi networks? How is the selection made?
Bob
K6ECM
I ran the OS menu once, but I don’t remember what it was and the wifi
…mike/kb8jnm
Bob
K6ECM
Sent from iPad
Nathan Hardman
http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-usersTo unsubscribe from this list please visit http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the bottom of the page. Enter your email address and press the “Unsubscribe or edit options button”
Manually edit the /etc/wpa_supplicant.conf file. WiFi-setup script created a template for three WiFi networks. Just replace SSID and PASSWORD in the file.
Bob
K6ECM
Sent from iPad
…mike/kb8jnm
Bob
K6ECM
Sent from iPad
Nathan Hardman
Understand. I’ll ask it differently. Suppose I have 3 WiFi networks entered. How is each selected? I’m assuming it does not connect to three at once.
Bob
K6ECM
Sent from my iPhone
Bob
K6ECM
Sent from iPad
…mike/kb8jnm
Bob
K6ECM
Sent from iPad
Nathan Hardman
I believe it goes from the first with a try and then to the next until it connects, so watch the order you put them in...
just think it through your situation to keep connect times shorter.
Common to use #1 as the one you are most likely to connect to most of the time etc...
...mike/kb8jnm
Bob
K6ECMSent from iPad
Sent from my iPhone
Bob
K6ECMSent from iPad
setup is in there. But you can find it on the web....mike/kb8jnm
Bob
K6ECMSent from iPad
You do not need a password to unsubscribe, you can do it via email confirmation. If you have trouble unsubscribing, please send a message to the list detailing the problem._______________________________________________
You do not need a password to unsubscribe, you can do it via email confirmation. If you have trouble unsubscribing, please send a message to the list detailing the problem.--
Nathan Hardman
N8THN@ARRL.NET_______________________________________________
