Hello, I am seeking guidance on setting up ASL on a Pi Zero 2 W. It has a MMDVM installed and when I try to select a Radio Interface I have 5 options.SimpleUSB, USBRadio, RTCM, No Radio and USRP. I am not sure which one to choose. I want to use a FM transceiver radio and use the Pi zero running ASL.
An MMMDVM board or hat is a modem for decoding various digital modes. AllStarLink is working with analog audio, and needs a sound adapter. Those two items are not compatible because they do fundamentally different things.
If you are looking for digital mode hotspots then you need to be looking at PiStar or W0CHP WSPD. If you want to use AllStarLink then you need to purchase a compatible sound adapter like an RA 25 or a URIx DNK. You could also obtain a complete kit from HotSpotRadios or SHARI or a few other makers.
