Anyone else having issue with raspbian stretch not setting host name and static IP?
I need to set a static IP and specific gateway and I am not familiar with debian’s methods.
If some can send me an example config file and location? I assume it goes to /etc/network/interfaces.d?
I just don’t know the format and what the file name should be.
I’ll worry about the host name another time.
Thanks.
I usually just set a static DHCP lease in my router for the mac address of that pi. That way I am not trying to mess around with setting a static IP on the pi itself. From what I remember, there was a specific way to do it in stretch, but I never got it to work and that’s when I started using static DHCP leases on the router.
Jeff Lehman, KC8QCH
E-mail: kc8qch@gmail.com
Hamshack Hotline: 4218
Yes I agree, I do the same. But I have one node that requires a custom setting due to how I am hopping on the network via a WIFI AP. I can’t rely on DHCP for this one.
Jeff Lehman, KC8QCH
You may want to update /etc/resolv.conf and /etc/hostname to have the proper
host name in it.
That should make it static no problem.
static IP? I need to set a static IP and specific gateway and I am not
familiar with debian’s methods. If some can send me an example config file
and location? I assume it goes to /etc/network/interfaces.d? I just don’t
know the format and what the file name should be. I’ll worry about the host
name another time. Thanks.
Thanks Bryan for the info.
One thing for certain is that the host name never gets set. I have done over 1/2 a dozen and each time I try to set host name or even domain name, it won’t set it. It defaults to repeated and no domain name.
But I’ll do it manually now that you refreshed my mind.
Thanks.
Sent from my iPhone, Lu Vencl
I'm not aware of any bug, I've statically provisioned one before. Can you
confirm this?
Basically it's Debian, and uses /etc/network/interfaces
