Asl-menu backup in command line mode?
Hi all,
Is there a way to use the backup feature present in the asl-menu in command line ?
I would like to use it in a cron.
Thanks and seventy threes,
Not currently. But, most of the bits needed to put something together are present in the current asl-backup-menu script. I’ll ask that you create an issue @ GitHub : asl3-menu with what you’d like to see (e.g. create a local backup, create a local backup and push the archive to the ASL backup server, etc).
Alternatively, if you are comfortable with shell scripting then we’ll most certainly welcome a pull request.
