[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 6.6.31+rpt-rpi-v8 (serge@raspberrypi.com) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29)
[ 0.000000] KASLR enabled
[ 0.000000] random: crng init done
[ 0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001e400000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x000000001e400000..0x000000002e3fffff (262144 KiB) map reusable linux,cma
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] On node 0, zone DMA: 19456 pages in unavailable ranges
[ 0.000000] percpu: Embedded 30 pages/cpu s85672 r8192 d29016 u122880
[ 0.000000] pcpu-alloc: s85672 r8192 d29016 u122880 alloc=30*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: ARM erratum 843419
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty1 root=PARTUUID=f2159055-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 238896
[ 0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[ 0.000000] Memory: 650236K/970752K available (13376K kernel code, 2210K rwdata, 4264K rodata, 4864K init, 1083K bss, 58372K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 43180 entries in 169 pages
[ 0.000000] ftrace: allocated 169 pages with 4 groups
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: bcm2836_arm_irqchip_handle_irq
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000001] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000425] Console: colour dummy device 80x25
[ 0.000442] printk: console [tty1] enabled
[ 0.001345] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[ 0.001397] pid_max: default: 32768 minimum: 301
[ 0.001521] LSM: initializing lsm=capability,integrity
[ 0.001802] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.001859] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.002984] cgroup: Disabling memory control group subsystem
[ 0.005204] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.005361] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.005531] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[ 0.005869] rcu: Hierarchical SRCU implementation.
[ 0.005895] rcu: Max phase no-delay instances is 1000.
[ 0.008166] EFI services will not be available.
[ 0.008628] smp: Bringing up secondary CPUs ...
[ 0.009475] Detected VIPT I-cache on CPU1
[ 0.009644] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.010568] Detected VIPT I-cache on CPU2
[ 0.010685] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.011531] Detected VIPT I-cache on CPU3
[ 0.011634] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.011759] smp: Brought up 1 node, 4 CPUs
[ 0.011890] SMP: Total of 4 processors activated.
[ 0.011915] CPU features: detected: 32-bit EL0 Support
[ 0.011936] CPU features: detected: 32-bit EL1 Support
[ 0.011961] CPU features: detected: CRC32 instructions
[ 0.012331] CPU: All CPU(s) started at EL2
[ 0.012373] alternatives: applying system-wide alternatives
[ 0.015411] devtmpfs: initialized
[ 0.028727] Enabled cp15_barrier support
[ 0.028797] Enabled setend support
[ 0.029090] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.029148] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.042243] pinctrl core: initialized pinctrl subsystem
[ 0.043137] DMI not present or invalid.
[ 0.043926] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.051039] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.051446] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.052053] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.052218] audit: initializing netlink subsys (disabled)
[ 0.052575] audit: type=2000 audit(0.052:1): state=initialized audit_enabled=0 res=1
[ 0.053472] thermal_sys: Registered thermal governor 'step_wise'
[ 0.053542] cpuidle: using governor menu
[ 0.053878] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.054056] ASID allocator initialised with 32768 entries
[ 0.055209] Serial: AMBA PL011 UART driver
[ 0.061645] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.072543] raspberrypi-firmware soc:firmware: Attached to firmware from 2024-05-24T15:31:28, variant start
[ 0.076539] raspberrypi-firmware soc:firmware: Firmware hash is 4942b7633c0ff1af1ee95a51a33b56a9dae47529
[ 0.084923] Modules: 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[ 0.084965] Modules: 0 pages in range for non-PLT usage
[ 0.084973] Modules: 517792 pages in range for PLT usage
[ 0.090435] bcm2835-dma 3f007000.dma-controller: DMA legacy API manager, dmachans=0x1
[ 0.092274] iommu: Default domain type: Translated
[ 0.092306] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.092911] SCSI subsystem initialized
[ 0.093208] usbcore: registered new interface driver usbfs
[ 0.093279] usbcore: registered new interface driver hub
[ 0.093366] usbcore: registered new device driver usb
[ 0.093913] pps_core: LinuxPPS API ver. 1 registered
[ 0.093940] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.093992] PTP clock support registered
[ 0.096929] vgaarb: loaded
[ 0.097574] clocksource: Switched to clocksource arch_sys_counter
[ 1.720229] VFS: Disk quotas dquot_6.6.0
[ 1.720334] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.720516] FS-Cache: Loaded
[ 1.720831] CacheFiles: Loaded
[ 1.731499] NET: Registered PF_INET protocol family
[ 1.731833] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.733875] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 1.733947] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 1.733995] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.734212] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 1.734652] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.735101] MPTCP token hash table entries: 1024 (order: 2, 24576 bytes, linear)
[ 1.735217] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.735297] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.735568] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.736357] RPC: Registered named UNIX socket transport module.
[ 1.736388] RPC: Registered udp transport module.
[ 1.736409] RPC: Registered tcp transport module.
[ 1.736431] RPC: Registered tcp-with-tls transport module.
[ 1.736453] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.736503] PCI: CLS 0 bytes, default 64
[ 1.737182] Trying to unpack rootfs image as initramfs...
[ 1.737204] kvm [1]: IPA Size Limit: 40 bits
[ 1.739067] kvm [1]: Hyp mode initialized successfully
[ 1.743605] Initialise system trusted keyrings
[ 1.744081] workingset: timestamp_bits=46 max_order=18 bucket_order=0
[ 1.744188] zbud: loaded
[ 1.745257] NFS: Registering the id_resolver key type
[ 1.745334] Key type id_resolver registered
[ 1.745357] Key type id_legacy registered
[ 1.745410] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.745442] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.746626] Key type asymmetric registered
[ 1.746678] Asymmetric key parser 'x509' registered
[ 1.746778] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.747178] io scheduler mq-deadline registered
[ 1.747209] io scheduler kyber registered
[ 1.747267] io scheduler bfq registered
[ 1.750439] pinctrl-bcm2835 3f200000.gpio: GPIO_OUT persistence: yes
[ 1.754756] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes
[ 1.754839] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 1.776642] Console: switching to colour frame buffer device 240x67
[ 1.796460] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[ 1.801725] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 1.805059] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.805978] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.826554] brd: module loaded
[ 1.837789] loop: module loaded
[ 1.838749] Loading iSCSI transport class v2.0-870.
[ 1.845116] usbcore: registered new device driver r8152-cfgselector
[ 1.845367] usbcore: registered new interface driver r8152
[ 1.845528] usbcore: registered new interface driver lan78xx
[ 1.845744] usbcore: registered new interface driver smsc95xx
[ 1.846190] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.574970] Core Release: 2.80a
[ 2.575149] Setting default values for core params
[ 2.575274] Finished setting default values for core params
[ 2.762951] Freeing initrd memory: 11860K
[ 2.775840] Using Buffer DMA mode
[ 2.775917] Periodic Transfer Interrupt Enhancement - disabled
[ 2.776028] Multiprocessor Interrupt Enhancement - disabled
[ 2.776135] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.776234] Dedicated Tx FIFOs mode
[ 2.777921] WARN::dwc_otg_hcd_init:1072: FIQ DMA bounce buffers: virt = ffffffc080b9a000 dma = 0x00000000de800000 len=9024
[ 2.778186] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.778564] dwc_otg: Microframe scheduler enabled
[ 2.778615] WARN::hcd_init_fiq:496: MPHI regs_base at ffffffc08006d000
[ 2.778847] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.778981] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.779154] dwc_otg 3f980000.usb: irq 74, io mem 0x00000000
[ 2.779312] Init: Port Power? op_state=1
[ 2.779392] Init: Power Port (0)
[ 2.779745] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 2.779905] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.784733] usb usb1: Product: DWC OTG Controller
[ 2.789430] usb usb1: Manufacturer: Linux 6.6.31+rpt-rpi-v8 dwc_otg_hcd
[ 2.794203] usb usb1: SerialNumber: 3f980000.usb
[ 2.799864] hub 1-0:1.0: USB hub found
[ 2.804674] hub 1-0:1.0: 1 port detected
[ 2.810075] dwc_otg: FIQ enabled
[ 2.810085] dwc_otg: NAK holdoff enabled
[ 2.810093] dwc_otg: FIQ split-transaction FSM enabled
[ 2.810111] Module dwc_common_port init
[ 2.811089] usbcore: registered new interface driver uas
[ 2.815949] usbcore: registered new interface driver usb-storage
[ 2.821489] mousedev: PS/2 mouse device common for all mice
[ 2.829249] sdhci: Secure Digital Host Controller Interface driver
[ 2.834073] sdhci: Copyright(c) Pierre Ossman
[ 2.838972] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.846110] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.851243] hid: raw HID events driver (C) Jiri Kosina
[ 2.856167] usbcore: registered new interface driver usbhid
[ 2.860863] usbhid: USB HID core driver
[ 2.871770] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 2.878097] NET: Registered PF_PACKET protocol family
[ 2.883059] Key type dns_resolver registered
[ 2.921760] Indeed it is in host mode hprt0 = 00021501
[ 2.925548] registered taskstats version 1
[ 2.932704] Loading compiled-in X.509 certificates
[ 2.951900] Key type .fscrypt registered
[ 2.956605] Key type fscrypt-provisioning registered
[ 2.974096] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.979315] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.985785] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.990401] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 3.019022] sdhost: log_buf @ 000000005e818ab9 (c57b3000)
[ 3.074243] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.079017] uart-pl011 3f201000.serial: there is not valid maps for state default
[ 3.084023] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.089110] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 99, base_baud = 0) is a PL011 rev2
[ 3.096597] of_cfs_init
[ 3.101485] of_cfs_init: OK
[ 3.106425] clk: Disabling unused clocks
[ 3.113651] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.118807] Indeed it is in host mode hprt0 = 00001101
[ 3.126791] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.127039] Freeing unused kernel memory: 4864K
[ 3.136573] mmc0: Host Software Queue enabled
[ 3.136613] Run /init as init process
[ 3.141307] mmc0: new high speed SDHC card at address 5048
[ 3.145935] with arguments:
[ 3.145940] /init
[ 3.150675] with environment:
[ 3.150681] HOME=/
[ 3.150688] TERM=linux
[ 3.152551] mmcblk0: mmc0:5048 SD32G 28.8 GiB
[ 3.162588] mmcblk0: p1 p2
[ 3.168780] mmcblk0: mmc0:5048 SD32G 28.8 GiB
[ 3.222386] mmc1: new high speed SDIO card at address 0001
[ 3.338202] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
[ 3.338229] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.339131] hub 1-1:1.0: USB hub found
[ 3.339278] hub 1-1:1.0: 5 ports detected
[ 3.633652] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.742170] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 3.749624] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.761037] smsc95xx v2.0.0
[ 3.891573] SMSC LAN8700 usb-001:003:01: attached PHY driver (mii_bus:phy_addr=usb-001:003:01, irq=184)
[ 3.903279] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:7a:bf:88
[ 3.989978] usb 1-1.4: new low-speed USB device number 4 using dwc_otg
[ 4.271565] usb 1-1.4: New USB device found, idVendor=03f0, idProduct=034a, bcdDevice= 1.21
[ 4.276896] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.282415] usb 1-1.4: Product: HP Elite USB Keyboard
[ 4.288021] usb 1-1.4: Manufacturer: Chicony
[ 4.364936] input: Chicony HP Elite USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:03F0:034A.0001/input/input0
[ 4.393581] raid6: neonx8 gen() 1095 MB/s
[ 4.430674] hid-generic 0003:03F0:034A.0001: input,hidraw0: USB HID v1.10 Keyboard [Chicony HP Elite USB Keyboard] on usb-3f980000.usb-1.4/input0
[ 4.465654] raid6: neonx4 gen() 1076 MB/s
[ 4.490425] input: Chicony HP Elite USB Keyboard System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:03F0:034A.0002/input/input1
[ 4.537577] raid6: neonx2 gen() 1032 MB/s
[ 4.554273] input: Chicony HP Elite USB Keyboard Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.1/0003:03F0:034A.0002/input/input2
[ 4.560979] hid-generic 0003:03F0:034A.0002: input,hidraw1: USB HID v1.10 Device [Chicony HP Elite USB Keyboard] on usb-3f980000.usb-1.4/input1
[ 4.609611] raid6: neonx1 gen() 877 MB/s
[ 4.681635] raid6: int64x8 gen() 694 MB/s
[ 4.753585] raid6: int64x4 gen() 764 MB/s
[ 4.825592] raid6: int64x2 gen() 685 MB/s
[ 4.897633] raid6: int64x1 gen() 506 MB/s
[ 4.903666] raid6: using algorithm neonx8 gen() 1095 MB/s
[ 4.977574] raid6: .... xor() 810 MB/s, rmw enabled
[ 4.983508] raid6: using neon recovery algorithm
[ 4.992225] xor: measuring software checksum speed
[ 5.006343] 8regs : 1241 MB/sec
[ 5.020244] 32regs : 1252 MB/sec
[ 5.034874] arm64_neon : 1148 MB/sec
[ 5.040672] xor: using function: 32regs (1252 MB/sec)
[ 5.048008] async_tx: api initialized (async)
[ 5.467711] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 5.473904] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 6.355810] EXT4-fs (mmcblk0p2): recovery complete
[ 6.363825] EXT4-fs (mmcblk0p2): mounted filesystem 56f80fa2-e005-4cca-86e6-19da1069914d ro with ordered data mode. Quota mode: none.
[ 7.232287] systemd[1]: System time before build time, advancing clock.
[ 7.495828] NET: Registered PF_INET6 protocol family
[ 7.503926] Segment Routing with IPv6
[ 7.510011] In-situ OAM (IOAM) with IPv6
[ 7.614952] systemd[1]: systemd 252.26-1~deb12u2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 7.628035] systemd[1]: Detected architecture arm64.
[ 7.674144] systemd[1]: Hostname set to <node29627>.
[ 8.996957] systemd[1]: Queued start job for default target multi-user.target.
[ 9.026445] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ 9.043292] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ 9.059712] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[ 9.075433] systemd[1]: Created slice user.slice - User and Session Slice.
[ 9.090242] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[ 9.105016] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[ 9.120623] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[ 9.135361] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-f2159055\x2d01.device - /dev/disk/by-partuuid/f2159055-01...
[ 9.150084] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[ 9.164580] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[ 9.179020] systemd[1]: Reached target paths.target - Path Units.
[ 9.193028] systemd[1]: Reached target slices.target - Slice Units.
[ 9.206645] systemd[1]: Reached target swap.target - Swaps.
[ 9.220308] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[ 9.235286] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[ 9.250198] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[ 9.266734] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[ 9.282912] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ 9.299623] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[ 9.316581] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ 9.333133] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ 9.350082] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[ 9.382157] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[ 9.405766] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[ 9.428771] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[ 9.447111] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[ 9.463874] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[ 9.518714] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[ 9.544471] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[ 9.572970] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[ 9.600271] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[ 9.626497] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[ 9.654123] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[ 9.681950] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[ 9.698613] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[ 9.738815] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[ 9.766399] systemd[1]: Starting systemd-fsck-root.service - File System Check on Root Device...
[ 9.788120] fuse: init (API version 7.39)
[ 9.818448] systemd[1]: Starting systemd-journald.service - Journal Service...
[ 9.848920] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[ 9.903175] systemd[1]: Starting systemd-time-wait-sync.service - Wait Until Kernel Time Synchronized...
[ 9.932819] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[ 9.975725] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[ 10.008077] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[ 10.026160] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[ 10.045397] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
[ 10.069515] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[ 10.090003] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 10.102022] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[ 10.121841] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 10.138097] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[ 10.159012] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 10.168699] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[ 10.188047] systemd[1]: Started systemd-journald.service - Journal Service.
[ 10.297738] dahdi: loading out-of-tree module taints kernel.
[ 10.318286] dahdi: Version: 3.3.0
[ 10.332655] dahdi: Telephony Interface Registered on major 196
[ 10.349965] dahdi_transcode: Loaded.
[ 10.364970] dahdi: Warning: Span DAHDI_DUMMY/1 didn't specify a spantype. Please fix driver!
[ 10.366584] dahdi_dummy: Trying to load High Resolution Timer
[ 10.366607] dahdi_dummy: Initialized High Resolution Timer
[ 10.366611] dahdi_dummy: Starting High Resolution Timer
[ 10.366628] dahdi_dummy: High Resolution Timer started, good to go
[ 10.564048] EXT4-fs (mmcblk0p2): re-mounted 56f80fa2-e005-4cca-86e6-19da1069914d r/w. Quota mode: none.
[ 10.674908] systemd-journald[270]: Received client request to flush runtime journal.
[ 12.659250] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.684259] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.686371] mc: Linux media interface: v0.10
[ 12.688403] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 12.688433] [vc_sm_connected_init]: start
[ 12.701789] rpi-gpiomem 3f200000.gpiomem: window base 0x3f200000 size 0x00001000
[ 12.703247] rpi-gpiomem 3f200000.gpiomem: initialised 1 regions as /dev/gpiomem
[ 12.703448] [vc_sm_connected_init]: installed successfully
[ 12.747638] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 12.853193] videodev: Linux video capture interface: v2.00
[ 12.992232] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.026198] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.040379] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.105132] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 13.140316] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 13.156709] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 13.179922] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 13.180011] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 13.191324] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 13.191428] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 13.194125] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 13.201538] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 13.201641] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 13.201665] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 13.201681] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 13.201696] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 13.208049] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 13.208119] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 13.212742] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 13.212821] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 13.223205] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 13.223282] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 13.270454] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 13.282055] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 13.283589] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 13.286611] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 13.286663] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 13.286686] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 13.286704] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 13.286719] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 13.298842] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 13.510993] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 13.567611] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[ 13.569329] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[ 13.572199] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 13.578139] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[ 13.950040] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[ 13.964618] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[ 13.966871] usbcore: registered new interface driver brcmfmac
[ 14.066229] Console: switching to colour dummy device 80x25
[ 14.073673] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 14.108775] Registered IR keymap rc-cec
[ 14.109099] rc rc0: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 14.109422] input: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0/input3
[ 14.134105] input: vc4-hdmi HDMI Jack as /devices/platform/soc/3f902000.hdmi/sound/card1/input4
[ 14.144668] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 14.145244] vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
[ 14.145742] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 14.146288] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 14.146629] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 14.146884] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 14.186520] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 14.243494] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[ 14.244513] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Jul 19 2021 03:24:18 version 7.45.98 (TOB) (56df937 CY) FWID 01-8e14b897
[ 14.360905] Console: switching to colour frame buffer device 240x67
[ 14.410059] vc4-drm soc:gpu: [drm] fb0: vc4drmfb frame buffer device
[ 14.828829] systemd-journald[270]: Data hash table of /run/log/journal/24a4fcffbf80ba7bdad51376668fd303/system.journal has a fill level at 75.0 (1552 of 2069 items, 1191936 file size, 768 bytes per hash table item), suggesting rotation.
[ 14.828898] systemd-journald[270]: /run/log/journal/24a4fcffbf80ba7bdad51376668fd303/system.journal: Journal header limits reached or header out-of-date, rotating.
[ 15.224615] Adding 1878012k swap on /var/swap. Priority:-2 extents:19 across:14548988k SS
[ 19.092535] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 19.096546] smsc95xx 1-1.1:1.0 eth0: Link is Up - 100Mbps/Full - flow control off
[ 19.163207] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[ 23.109561] sched: RT throttling activated
[ 33.210141] systemd[1003]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
